HP Envy X360 Laduree 1.0 MB 14257-2 turns on and off
  • TTR
    • Apr 2020
    • 24
    • Poland
    HP Envy X360
    Motherboard:Laduree 1.0 MB 14257-2
    CPU:SR23W i7-5500U
    KBC:ENE KB9028Q C
    At first, the board was dead no lights nothing after connecting the charger.
    After visual inspection, I noticed damaged components in the charging circuit:
    PR4408, PR4415, PR4416, PU4406
    I replaced them (including high side and low side MOSFETs PU4406 and PU4405).
    Later on the 20th leg of the charger, I still had low resistance, so I replaced the charger chip
    After replacing the charger chip I have a white led when I plug the charger.
    At this moment laptop behave like this:
    After I press the power button the light on the power button blink white for a second a fan twitch for a little
    After further measurements, I've noticed no voltage 3.3v and 5v on coils PL4501,PL4502
    Here are my measurements:
    Resistance on coils :
    PL4501 - Resistance in mega Ω
    PL4502 - Resistance in mega Ω
    PL4901 - 660k Ω
    PL1 - Resistance in mega Ω
    PL4701 - 62.9 Ω
    PL4801 - 233k Ω
    PL8201 - 21 Ω
    PU4503
    Pin 3 (VREG3) - 3.29v
    Pin 6 (EN2) - 0v
    Pin 12 (VIN) - 19.5v
    Pin 13 (VREG5) - 5v
    Pin 20 (EN1) - 0v
    Resistance:
    Pin 6 (EN2) - 12k Ω
    Pin 20 (EN1) - 12k Ω
    U2401
    Pin 67 (AVCC) - 3.29v
    Pin 91 (5V_S5_EN) - 0v
    Pin 101 (3V_S5_EN) - 0v
    Pin 103 (RSMRST#) - 0v
    Pin 110 (ACIN#) - 0v
    Pin 111 (VCC) - 3.29v
    Looks like KBC doesn't issue a turn-on signal for 3v/5v driver chip.
    I've tried to reprogram Bios and KBC chip with a dump from HP update and still, nothing changed, then I replaced KBC with a new one and programmed it with a dump from HP update and still nothing.
    I'm out of ideas right now.
    Thank you for any help and ideas on what I should do next.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP Envy X360 Laduree 1.0 MB 14257-2 turns on and off
    Link the schematic if available. What is the measurement for ACOK/ACDET/VCC/REGN pins??
    • TTR
      • Apr 2020
      • 24
      • Poland
      Schematic is available link is down below
      https://drive.google.com/file/d/1CxX...JchV4hgRl/view
      5 - ACOK#- 0v
      6 - ACDET- 2.6v
      20 - VCC- 19.4v
      16- REGN- 6v
      • mohammed mohan
        • Nov 2017
        • 196
        • z
        Mohammed Mohan
        • TTR
          • Apr 2020
          • 24
          • Poland
          Any ideas ?
          • mon2
            • Dec 2019
            • 14259
            What is the voltage of ACDRV pin on the charger IC?
            Check the voltage on the gate pin #4 of the 2x DCin mosfets.
            Post all measurements.
            • TTR
              • Apr 2020
              • 24
              • Poland
              Can't find ACDRV pin on my charger IC.
              I'll attach a part of schematic with my charging ic.
              On the gate of PU4402 and PU4403 I have 6.5V
              • mon2
                • Dec 2019
                • 14259
                For P-channel mosfets, the GATE voltage has to be more negative than the voltage it is passing to enable. Looks ok @ pin #4.
                Remove all power and check the resistance across the mosfets.
                • TTR
                  • Apr 2020
                  • 24
                  • Poland
                  PU4402
                  S-D 340k
                  D-S 340k
                  D-G 290k
                  G-D 290k
                  S-G 125k
                  G-S 125k
                  PU4403
                  S-D 235k and rising
                  D-S 235k and rising
                  D-G 400k and rising
                  G-D 400k and rising
                  S-G 100k
                  G-S 100k
                  • Sephir0th
                    • Oct 2020
                    • 1282
                    It's a HP. You're working with known good charger of correct wattage?
                    FairRepair on YouTube
                    • TTR
                      • Apr 2020
                      • 24
                      • Poland
                      I have tried with 2 different know good hp 65w chargers and got the same results.
                      Later I connected board to lab power supply with a prepared HP cable with resistor between + and ID pin which simulated 90w power supply
                      • mon2
                        • Dec 2019
                        • 14259
                        U2401- Pin 103 (RSMRST#) - 0v
                        Being an active LOW signal, this pin is stuck in reset mode.
                          HP ENVY x360 ENVY x360 - 15-dr1011na Hybrid (2-in-1) 15 Specification for Upgrade or Repair
                          This specification for the HP ENVY x360 ENVY x360 - 15-dr1011na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 - 15-dr1011na boardview and ENVY x360 - 15-dr1011na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                          09-06-2024, 12:18 PM
                          HP ENVY x360 ENVY x360 Convert15-dr1013na 7PW22EA Hybrid (2-in-1) Specification for Upgrade or Repair
                          This specification for the HP ENVY x360 ENVY x360 Convert15-dr1013na 7PW22EA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 Convert15-dr1013na 7PW22EA boardview and ENVY x360 Convert15-dr1013na 7PW22EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                          09-06-2024, 11:17 AM
                          HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) Specification for Upgrade or Repair
                          This specification for the HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 Convert 15-ds0502saBundle 6TD07EA boardview and ENVY x360 Convert 15-ds0502saBundle 6TD07EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                          HP ENVY x360 ENVY x360 15-cn0755nd Notebook Specification for Upgrade or Repair
                          This specification for the HP ENVY x360 ENVY x360 15-cn0755nd Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 15-cn0755nd boardview and ENVY x360 15-cn0755nd schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                          09-06-2024, 06:51 AM
                          HP ENVY x360 ENVY x360 - 15-cn0008ng Hybrid (2-in-1) Specification for Upgrade or Repair
                          This specification for the HP ENVY x360 ENVY x360 - 15-cn0008ng Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 - 15-cn0008ng boardview and ENVY x360 - 15-cn0008ng schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                          09-06-2024, 06:50 AM
