Lenovo g50-45 nm-a281 rev:1.0
  • NConstantinou
    • May 2017
    • 351
    • Cyprus
    motherboard has all voltages but no display
    near lcd connector there is an ic u7 which has pins 4,5 as inputs and i have 3.3v and on pin 3 en pin i have nothing. Is is not short.
    I replaced ic 523am with ic 523pm but no change.
    Am i on the right truck!
  • Sephir0th
    • Oct 2020
    • 1289
    Re: Lenovo g50-45 nm-a281 rev:1.0
    Without CapsLock responding on external keyboard there is no point to troubleshoot the display circuit. You did check that?
    FairRepair on YouTube
    • NConstantinou
      • May 2017
      • 351
      • Cyprus
      thanks for your reply
      do you suggest that i must have the keyboard connected in order to have
      display!
      pls explain.
      i have used external usb keyboard BUT no light
      thanks
      • JaroTech
        • Mar 2015
        • 351
        Hi, do you have a picture on an external monitor?
        • Sephir0th
          • Oct 2020
          • 1289
          The external USB-Keyboard is the best indicator for proving that the device actually does the P.O.S.T.
          In your case it does NOT so initialisation is not completed and you won't get picture for this reason.
          So in my opinion you should work backwards from PLT_RST# and if everything is fine, troubleshoot the BIOS.
          • NConstantinou
            • May 2017
            • 351
            • Cyprus
            Thanks Sephir0th for the reply
            Troubleshooting all signals seems to work ok.
            i will try to flash Bios tomorrow to see what will happen But worries me U7 enable pin3 no voltage
            thanks
            • Sephir0th
              • Oct 2020
              • 1289
              Like I told, no need to worry about this area as long as the board does not successfully complete the P.O.S.T.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                It is always important to understand the logic and sequence of signal/voltages before troubleshooting. When mb is not even posting, it definitely doesnt makes sense probing LCD circuit as @sephirtOth has mentioned.
                • NConstantinou
                  • May 2017
                  • 351
                  • Cyprus
                  If I tested all 13 points (power sequence from 1-13) point 13 is pls_rst# and all measurements look ok. There was a block diagram on the schematic for power sequence.
                  What is the next step I should take!
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Dramrst# is not pulled low??
                    • NConstantinou
                      • May 2017
                      • 351
                      • Cyprus
                      Dear mcplslg123
                      i do not have DRAMRST# but i do have MEM_MA_RST# on pin30 of ddr3 which is 0v
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        What we call DRAMRST# on intel platform is called MEM_MA_RST# on amd platform. This should not be zero volts and most of the times its APU fault.
                        • NConstantinou
                          • May 2017
                          • 351
                          • Cyprus
                          According to schematics MEM_MA_RST# is generated from G38 on CPU, then is link to dimm's on pin30.
                          if there is no voltage on DIMMA and DIMMB and the resistance is .325 in diode mode without ram. with ran on pin 30 of DIMM's is 0.
                          then what to do!
                          thanks
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Already answered. There is nothing inbetwwen cpu and ram slot pin30. So it can be either bios and/or APU.
                            • coasterghost
                              Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                              by coasterghost
                              For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                              Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                              Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                              System Hardware:
                              Processor: AMD Ryzen 7 PRO 5850U
                              Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                              09-08-2025, 10:46 PM
                              Lenovo 3000 Series Schematic
                              Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                              3000 C100 laptop with Braille keyboard
                              Lenovo 3000 C
                              C100, C200 - 15-inch XGA screen
                              Lenovo 3000 N
                              N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                              N500 - 15.4 inch screen.
                              Lenovo 3000 V
                              V100, V200 - 12.1-inch WXGA models
                              Lenovo 3000 G
                              G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                              10-04-2024, 06:05 AM
                              Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                              This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                              09-06-2024, 06:40 AM
                              This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                              09-06-2024, 06:06 AM
                            • derradji89
                              Need help Lenovo MIX 320-10lCR domaine name SERCOL
                              by derradji89
                              Hi everyone 🤗
                              I have a Lenovo MIX 320-10lCR computer.**
                              1. **Operating System**: Windows 10 ** Education** 64-bit.
                              2. **User Account Restrictions**: The account I'm using has heavily restricted permissions via **UAC** and **Group Policy**. This means I cannot install any software without admin rights, adjust system time, run Command Prompt as administrator, or modify the registry via Regedit—all are blocked.
                              3. **BIOS Password Protection**: The BIOS is locked with a password, preventing me from installing a new operating system.
                              4. **BIOS Chip Reflashing**: Currently,...
                              04-19-2025, 03:04 PM
