Acer Aspire E5-575 Mosfet
  • spike3333
    • Jan 2014
    • 43
    I have a Acer Aspire E5-575 that died. The power supply checked out. When the power supply was plugged in, the board was getting voltage but neither the battery charging light or the power light came on. I removed the first Mosfet (PQ22) and AON6414AL and jumped it and both lights came on and the laptop started normally. I assumed that it was a bad Mosfet and ordered one. After soldering in the new Mosfet, I get no lights again. I attached the circuit for reference. I am not an EE, so I was not able to do any more troubleshooting. Any suggestions on the next steps would be appreciated. Thanks
  • mon2
    • Dec 2019
    • 14213
    Re: Acer Aspire E5-575 Mosfet
    With extreme care, measure the voltage on each pin of the charger IC @ PU5. Post your measurements.
    • Duranitron
      • Jul 2014
      • 544
      • Philippines
      Measure the vcc of pu5.
      Never stop LEARNING because life never stops TEACHING!
      • piernov
        • Jan 2016
        • 4435
        • France
        https://www.badcaps.net/forum/showpo...02&postcount=2
        https://www.badcaps.net/forum/showthread.php?t=90356
        • spike3333
          • Jan 2014
          • 43
          Can you list which pins you want me to post voltage readings of please
          • mon2
            • Dec 2019
            • 14213
            Regn
            acok
            acdet
            acdrv
            vcc
            • spike3333
              • Jan 2014
              • 43
              Is it safe to test this with the Mosfet jumped or should I remove the jump and put back in the new Mosfet I purchased?
              • mon2
                • Dec 2019
                • 14213
                Wait till you have the proper mosfets install onboard. Never jump anything till more is known about the logic board.
                Wish to confirm if the charger is able to see the conditions to enable the internal charge pump to boost the voltage from REGN (~6 volts) to drive the 2 x DCin N-channel mosfets.
                • spike3333
                  • Jan 2014
                  • 43
                  I had to remove the PCB to get to this IC. Should I attach the battery for these measurements?
                  • spike3333
                    • Jan 2014
                    • 43
                    ACDRV ~4V
                    VCC 19V
                    ACDET 2.6 V
                    ACOK 0 V
                    REGN 6 V
                    Same with or without battery
                    • mon2
                      • Dec 2019
                      • 14213
                      ACDRV is too low. It should be ~25v for the gate pin on a normal system (19v + REGN voltage of 6v = ~25v).
                      Locate and remove the 4k resistor that is in series @ PR165. Do not lose this part.
                      Then power up again and measure the ACDRV voltage at the charger IC.
                      • spike3333
                        • Jan 2014
                        • 43
                        With the resistor removed and the trace open the measurement at pin 4 (ACDR) is in the microvolts
                        • mon2
                          • Dec 2019
                          • 14213
                          with no power, confirm the operation of PQ22 mosfet by checking the resistance values. If you see '1' or 'OL' on the meter -> switch to a higher resistance scale.
                          Measure the resistance as follows:
                          Source (1-2-3) & drain (5-6-7-8)
                          Source (1-2-3) & gate (4)
                          Gate (4) & drain (5-6-7-8)
                          Post each measurement and the meter scale used.
                          • spike3333
                            • Jan 2014
                            • 43
                            Should I replace the 4k resistor first
                            • mon2
                              • Dec 2019
                              • 14213
                              No, not for these resistance checks.
                              • spike3333
                                • Jan 2014
                                • 43
                                The only reading I get is .95 Mohm across source and drain. All the others are OL. It's a cheap mutimeter that states it will read from 400 ohm to 40 Mohm with 1 percent accuracy.
                                What should the readings be?
                                • spike3333
                                  • Jan 2014
                                  • 43
                                  Just wondering if the readings indicate that the laptop is beyond repair or if anything more can be done, thanks
                                  • Sephir0th
                                    • Oct 2020
                                    • 1282
                                    Issues in DC-IN circuitry usually should be repairable. Especially since you stated it is working when you jumper the MOSFETs, which btw was a very dangerous task in case you have a Main Power retail shorted to any High-Side or even to GND.
                                    So you probably have "just" something wrong around the charging controller, where was already asked for some measurements. You should measure resistance to GND of any pin without power to check for unexpected shorts and even better all pins present voltages. Be careful to not short any pins together while doing so.
                                    FairRepair on YouTube
                                    • spike3333
                                      • Jan 2014
                                      • 43
                                      So resistance measurements on PU5, test all pins to GND with and without power applied to MB, testing for shorts only, is that correct?
                                        ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                        This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        09-12-2024, 03:28 PM
                                        ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                        This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        09-12-2024, 02:30 PM
                                        ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                        This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                        09-06-2024, 05:27 AM
                                        ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                                        This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
