Macbook A2338 820-02020
  • Instafixx
    • Jul 2022
    • 374
    • India
    Received a dead Macbook A2338 820-02020.
    Voltage on PPBUSG3H_AON IS .5 Volts.
    Can anyone here guide where to start looking for short or faulty components.
  • mon2
    • Dec 2019
    • 14675
    Re: Macbook A2338 820-02020
    Remove all power. Measure the resistance to ground of the rail you deem to be low. Checking for shorted caps.
    • Instafixx
      • Jul 2022
      • 374
      • India
      You mean PPBUs_AON
      • Instafixx
        • Jul 2022
        • 374
        • India
        I checked PPBUS_AON and found no short. Can you suh=ggest any other rail htat i should check?
        • mon2
          • Dec 2019
          • 14675
          It is very important to use only the full netnames from the schematic so we can follow the signals.
          Yes, PPBUS_AON which is too low.
          What is the exact resistance on this rail to ground ? No power -> meter in resistance mode (not diode mode). Post the reading and the scale used on your meter.
          With the adapter connected to the logic board -> check if you have a voltage on pin # 1 of the fuse @ F5200. It is possible that the fuse is blown.
          What is the input voltage for this buck / boost regulator @ U5200 (measure PPDCIN_USBC_AON) ?
          • Orux
            Macbook Pro M1 A2338 13"
            by Orux
            I’m new to the forum and could use a bit of help. My name is Tom and I have a problem 😅
            I bought a MacBook Pro M1 and also got a second one for spare parts. The seller told me it had a small water spill. After opening it, I found four spots with corrosion on the board.
            One of those spots has damaged components — I’m not sure if they’re capacitors or other SMD parts. I’ve already cleaned the whole board with isopropanol, which made the other areas look fine. But could those damaged caps be the reason why the MacBook won’t power on?...
            09-22-2025, 12:54 PM
          • sdogs
            macbook pro M1 a2338 no video on internal display PP3V3_S2 short
            by sdogs
            Greetings to the entire forum, I ask you for help because I'm going crazy. A dear friend of mine gave me a macbook pro M1 A2338 that only works with an external screen. With the internal one, no backlight or image. Only the external display is detected from the system settings.
            First I changed the display flat, then I made a backup with time machine and tried a reset in dfu but nothing to do, always the same problem.
            I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was...
            06-27-2025, 01:58 PM
          • sdogs
            by sdogs
            06-27-2025, 11:26 AM
          • classicandy
            MacBook Pro A2338 [820-02773] No Audio (Speakers and Microphone)
            by classicandy
            Hi Everyone,
            Please, I have a MacBook Pro A2338 M2, board number : 820-02773. The speakers and the microphone of the Mac are not working and I need assistance in fixing.
            UR730 got damaged and short-circuited the motherboard. After removing the shortened IC; before and after putting the new one I ordered, the speakers [specifically the other one not affected by this IC] and the microphone are still not working. I do have sound through a Bluetooth speaker device or when I connect a headphone with microphone to the jack 3.5mm input. Also, media files do not play unless ​a...
            04-14-2024, 12:00 PM
          • User555111
            A2338 13" 2022 MacBook Pro M2 820-02773 Touchpad/Keyboard/Display not working
            by User555111
            Currently Im trying to get this A2338 13" 2022 MacBook Pro M2 to function properly, Right now the trackpad and keyboard are not working but the power button and keyboard backlight are working. the Touch Bar shows display but does not respond to touch. I bought it on eBay and it was described as having a bad lcd. When I received it however I found that it was also missing the wifi and bluetooth antenna along with most of the screws hardware. it was also showing picture on the LCD but no backlight, I could also see some lines on the screen indicating the lcd was also somewhat damaged. on top...
            02-05-2024, 08:16 AM
