Lenovo EC section won't upgrade or downgrade
  • pingaroon
    • Nov 2019
    • 121
    • uk
    I've successfully updated both main and ec sections on hundreds of lenovo boards without issue (and without a battery to hand). Some of them, however, refuse to touch the EC, no matter what I try.
    Ordinarily, the following command from an admin dos shell works perfectly to update both main and ec:
    (after extracting the contents of the official bios .exe):
    winuptp64 /sp /ipf all /file Rxxxxxx\*.*
    The latest problem is with an X270. I can upgrade and downgrade the main bios without issue, but the EC is stuck at 1.17
    Looking at this page:
    https://pcsupport.lenovo.com/de/en/p...loads/ds120442
    shows the latest bios version is 1.46 (main) and 1.18 (ec) for machine type 20HM (this board)
    so running the update command should update the EC to 1.18.
    Downgrading to an older version, eg to a version which has an older main *and* an older ec, such as version 1.23, does not complain - the machine boots and it downgrades the main bios first, but then reboots without touching the EC.
    I have tried cleaning the ME, followed up with the usual FPT -GRESET command, but the problem persists.
    Does anybody know how I can update the EC when such a problem presents? I have encountered this quite a few times now
    winuptp64 /sp (I don't have a battery) /ipf ec /file Rxxxxx\*.FL2 does not fix it either, in cases where there are both FL1 and FL2 files.
    (please no comments such as "why do you want to change the EC if your machine works?" etc - we have customers who demand this, and sometimes the EC is massively out of date!)
    Thanks.
  • NanoTesting
    Lenovo Ideapad 15IIL05, turns on and off with charger BUT works by injecting 20v after main mosfets
    by NanoTesting
    I got a 15-IIL05 that failed to turn on BUT IT DID TRY TO TURN ON and then turned off after 30+- seconds, i disassembled it and found a screw loose inside the case.
    With charger it turns on, fan spins but gives no image.
    Tested main mosfets no short, tested 3.3v,5v,DRAM, CPU etc and they were present.
    Reflashed BIOS, same problem.
    Replaced both main mosfets.
    Checked main mosfets again and i noticed that they closed once the laptop shut down, so i decided to bypass them and used a bench PSU to check how much power the laptop was drawing while trying to turn on, 20v@3A,...
    10-30-2024, 10:48 PM
  • Andreasbest
    Lenovo T480s NM-B471 main Type C not working
    by Andreasbest
    Hello.
    Received a T480s with broken main Type C, i replaced it but it's not working (replaced it 3 times just to make sure everything is soldered correctly).
    Thunderbolt charging works and laptop power up fine.
    I need help to repair JUSBC port please.
    Thank you!
    Schematics: https://www.badcaps.net/forum/troubl...b471#post72970
    10-21-2024, 12:05 PM
  • questore
    Lenovo NM-D562 v2.0 main EC programming help needed
    by questore
    Hello Everyone,
    I have this board that has an autostart as soon as i connect the charger (no POST) and restarts after 20 seconds. cannot be turned off.
    I'm suspecting main EC firmware problem (IT8227E-192)
    Since this board has only EC_KSI6 and EC_KSI7 pin on keyboard connector to the EC this cannot be programmed trought it.
    I would like to know if anyone can give me instruction how to program the EC.
    In the Vertyanov tutorial instructions I have seen that alternative is using 8pin direct cable soldered to board.
    Anyone knows hows if that is working...
    07-09-2025, 01:52 AM
    Lenovo 3000 Series Schematic
    Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
    3000 C100 laptop with Braille keyboard
    Lenovo 3000 C
    C100, C200 - 15-inch XGA screen
    Lenovo 3000 N
    N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
    N500 - 15.4 inch screen.
    Lenovo 3000 V
    V100, V200 - 12.1-inch WXGA models
    Lenovo 3000 G
    G400, G410, G430, G450, G455, G510, G530, G550, and G560...
    10-04-2024, 06:05 AM
    Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
    This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
    09-06-2024, 06:40 AM
