HP Omen 17 AN113NS it does not work
  • tolatara
    • Oct 2021
    • 36
    • españa
    in the IC Charger BQ738H, in pin Nº16 I get 0V, without battery or with it, is this possible or what could be wrong?
  • mon2
    • Dec 2019
    • 14596
    Re: HP Omen 17 AN113NS it does not work
    Hi. Yes, it is possible.
    1) Post or link the schematic / boardview file for this logic board if available on this forum.
    2) Are you using the recommended power adapter and is suitable for this logic board ?
    3) Start with the DC in power connector -> confirm the voltage of the adapter is reaching this entry to the logic board. What is the voltage ?
    4) Next to the connector should be the usual 2 x DCin mosfets. Carefully measure and post the voltage on each pin of the mosfets (Source; Gate; Drain).
    5) We can study other partial schematics to understand how your logic board may have been designed for the BQ24738 charger IC. Most are clones from the TI datasheets.
    Pin # 6 of the charger = REGN LDO and should be ~6 volts.
    If it is not, confirm that the adapter voltage is available to this IC. It is very possible that this charger IC is defective.
    Available from Aliexpress or a donor board. However, the 2 x DCin mosfets need to be reviewed as well before you go shopping for replacement parts.
    • tolatara
      • Oct 2021
      • 36
      • españa
      First of all, thank you for the interest shown.
      • mon2
        • Dec 2019
        • 14596
        The voltages on the DCin mosfets look to be ok, including the gate being about 6 volts higher than the source and ~25 volts to enable the N-channel mosfets.
        However, the REGN LDO rail is not valid. It should not be this low and should be ~6 volts (always). Can you measure this rail again ?
        Remove all power -> meter on the lowest resistance scale.
        One meter lead on pin # 16 (REGN); other meter lead to ground.
        What is the resistance value to ground value ?
        Still with no power, confirm the operation of the same 2 x DCin mosfets by checking their resistance values. If you see '1' or 'OL' on the meter -> switch to a higher resistance scale.
        Measure the resistance of each of the 2 x dcin mosfets as follows:
        Source (1-2-3) & drain (5-6-7-8)
        Source (1-2-3) & gate (4)
        Gate (4) & drain (5-6-7-8)
        Post each measurement and the meter scale used.
        Repeat for the next mosfet.
        • tolatara
          • Oct 2021
          • 36
          • españa
          Source (1-2-3) & drain (5-6-7-8) 3450 M Ohmios in all
          Source (1-2-3) & gate (4) 3123 M Ohmios in all
          Gate (4) & drain (5-6-7-8) 4544 M Ohmios in all
          Pin 16 charger : 183 K Ohmios , 0 V
          Pin 6 : 2,679 V
          • mon2
            • Dec 2019
            • 14596
            The mosfet resistance values look good.
            Can you review and post the measurements now for the next mosfet ? Often, that is the one that dies.
            • tolatara
              • Oct 2021
              • 36
              • españa
              the same values in both mosfet
              • tolatara
                • Oct 2021
                • 36
                • españa
                I'll tell you what I've reviewed so far.
                When I connect the power supply, current arrives at 5v and 3v, but the 3v after about 2 seconds stays at 0v.
                The consumption indicated by the source is about 30mah and after about two seconds there is no more consumption.
                bios 3V arrive and disappear after 2 seconds.
                In the KBC no current arrives at pin vcc nº11.
                3v arrives at the power button and when I connect it stays at 0V.
                • tolatara
                  • Oct 2021
                  • 36
                  • españa
                  Please,Help me.
                  • mon2
                    • Dec 2019
                    • 14596
                    Check the voltage @
                    pin # 4 (ACDRV)
                    pin # 5 (ACPRES)
                    pin # 6 (ACDET)
                    pin # 16 (REGN)
                    pin # 20 (Vcc)
                    on the same charger IC (BQ738H) with the power adapter connected.
                    • tolatara
                      • Oct 2021
                      • 36
                      • españa
                      4-25,55
                      5-2,98
                      6-2,65
                      16-5,99
                      20-19,07
                      • mon2
                        • Dec 2019
                        • 14596
                        These are good voltage readings.
                        Measure the voltages on each of the DCIN mosfets and post their values.
                        source (1-2-3) & drain (5-6-7-8)
                        source & gate(4)
                        gate & drain
                        Gate on each of the mosfets should be ~ACDRV value that is created by the charger IC.
                        Interested to know if the mosfets are passing the adapter voltage onto the logic board.
                        After the board shuts off, do you continue to see the same voltages on the charger IC from your last post ?
                        • tolatara
                          • Oct 2021
                          • 36
                          • españa
                          19,67
                          25,53
                          6,05
                          In both
                          the same voltage on ic charger
                          • mon2
                            • Dec 2019
                            • 14596
                            In your posts, do apply labels to the voltages for the review.
                            Post the voltages on the 2nd mosfet. Gate voltage is great for both DCIN mosfets to enable each.
                            19v67 = DCIN adapter voltage.
                            Output of this mosfet is 6v05 ??
                            What is the voltage seen by the logic board with the adapter (only) - remove the battery for now.
                            • tolatara
                              • Oct 2021
                              • 36
                              • españa
                              I'm sorry I didn't answer before but the time difference is important. I also tell you that my knowledge in electronics is very small but I have the necessary tools to replace any component as a hobby. This laptop is mine and I would like to be able to revive it.My English is very basic but SAN google helps me. Having said this, I will tell you my measurements:
                              All of them are made without any connected hardware (battery, hard drive, etc...). Just the motherboard.
                              The two input mosfets measure with the power supply at 19.60V:
                              source (1-2-3) & drain (5-6-7-8) : 19,67v
                              source & gate(4) : 25,53v
                              gate & drain : 6,05v
                              The last two measurements I understand is to measure the voltage between source-gate and drain-gate.
                              In the first measurements of voltages in the mosfets, I imagine that I had the source at 18.80v by mistake.
                              • tolatara
                                • Oct 2021
                                • 36
                                • españa
                                By the way, when I connect the charger or source, at no time does the connection led light up. Curiously, it lights up if I feed 14.80v with the source. In case this gives you some idea of the problem
                                • tolatara
                                  • Oct 2021
                                  • 36
                                  • españa
                                  The 3 and 5 volt coils always work when I plug in the power supply. In about a second the 3.4 volt one stops working.
                                  • tolatara
                                    • Oct 2021
                                    • 36
                                    • españa
                                    Help,:llorando:
                                    • tolatara
                                      • Oct 2021
                                      • 36
                                      • españa
                                      Please :girar:
                                      • mon2
                                        • Dec 2019
                                        • 14596
                                        Can you confirm how these measurements were taken ?
                                        Meter in DC volts scale (20v or higher is ok).
                                        Red meter probe to source pins (1-2-3) ; pick one
                                        Black meter probe to ground (shield ground is ok)
                                        Then review the voltage on this pin.
                                        Repeat for the DRAIN pins (5-6-7-8).
                                        Repeat for the GATE pin (4).
                                        For each case, black meter probe to ground.
                                        Then the same check for the next mosfet.
                                          HP OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) OMEN 870 i5-6400 Specification for Upgrade or Repair
                                          This specification for the HP OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) boardview and OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          09-12-2024, 03:44 PM
                                          HP OMEN OMEN by Desktop PC - 870-265na OMEN 870 i5-7400 Specification for Upgrade or Repair
                                          This specification for the HP OMEN OMEN by Desktop PC - 870-265na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-265na boardview and OMEN OMEN by Desktop PC - 870-265na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          HP OMEN OMEN by Desktop PC - 870-010na (ENERGY STAR) OMEN i5-6400 Specification for Upgrade or Repair
                                          This specification for the HP OMEN OMEN by Desktop PC - 870-010na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-010na (ENERGY STAR) boardview and OMEN OMEN by Desktop PC - 870-010na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          HP OMEN OMEN by Desktop PC - 870-020na (ENERGY STAR) OMEN 870 i5-6400 Specification for Upgrade or Repair
                                          This specification for the HP OMEN OMEN by Desktop PC - 870-020na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-020na (ENERGY STAR) boardview and OMEN OMEN by Desktop PC - 870-020na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          HP OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) OMEN i7-6700 Specification for Upgrade or Repair
                                          This specification for the HP OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) boardview and OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
