Acer 5750G P5WE0 LA-6901P images only on external screen
  • mon2
    • Dec 2019
    • 14672
    Re: Acer 5750G P5WE0 LA-6901P images only on external screen
    Wish to confirm / note that you cannot perform resistance or diode checks if there is power to the logic board. It will not work.
    You must have all power removed for these tests unless we are discussing voltage checks.
    • Paul20
      • Jul 2022
      • 40
      • Italia
      Yes this is clear, and I already knew it, in fact I performed all the tests without power supply, God forbid.
      So do you think it is possible to do a test by jumpering the + 3VALW on pin 2 of Q1?
      Or do other tests need to be done?
      • mon2
        • Dec 2019
        • 14672
        What are the voltages on pins 1-2-3, 5 & 6 of the LCD connector (with the LCD connected) ?
        These are:
        1-2-3 : +INVPWR_B+
        5 : DISPOFF#
        6 : INVTPWM
        Review the voltages on mosfet @ Q28.
        Is pin # 3 = ~3 volts ?
        If yes, voltage on pin # 2 = gate ?
        Pin # 1 = is the pin that powers the LCD and it should be ~0 volts by default.
        To turn ON Q28 to pass the voltage through, the GATE voltage should be 'negative' or lower than the source voltage.
        That is, if you GROUND the gate of Q28, this mosfet should turn ON.
        Take a jumper wire and connect to pin # 2 (gate) of Q28 & other side of the wire to GROUND.
        Does this allow for the +LCDVDD pin to receive ~3 volts (through Q28, pin #1) ? Do not worry about Q1 as the effect is the same. If Q1 closes, then Q28 gate pin will be shorted to ground to turn on Q28.
        Q28 = P-channel mosfet so needs a LOWER voltage on the gate than the source pin (which should be ~3 volts on your box) to turn ON.
        Q1 = N-channel mosfet so it needs a HIGHER voltage on the gate than the source pin (which is 0 volts) so ~3 volts will fully turn on Q1 mosfet.
        Mosfets = like a water tap (have thoughts of drowning this circuit right about now).
        • Paul20
          • Jul 2022
          • 40
          • Italia
          All clear, therefore:
          Voltages with the LCD connected on pins 1-2-3 are 18.9V.
          On pins 5 and 6 no voltage.
          A note, my boardview, gives me pins 5 and 6 not connected, while pin 6 BKOFF and pin7 INVTPWM, I checked these too for safety and there is no voltage.
          The voltages on the Q28 are about 3.3V on pins 2 and 3 ... on pin 1 0V.
          I also checked Q1 and on its pin 1 there is about 3.3V
          So you think everything is ok?
          Do I proceed with the connect you told me about the Q28?
          The mass can I take it from C2 immediately close to Q28?
          • mon2
            • Dec 2019
            • 14672
            Yes, looks logical on the readings.
            To force Q28 mosfet (P-channel) to turn ON, yes, you can apply a jumper wire on C2 (pin # 1) and can short it to:
            a) C2, pin # 2 (since this is GROUND)
            (could even use tweezers but a wire is more stable to handle)
            or
            b) Ground anywhere else that is convenient.
            Then Q28 should turn ON and pass the voltage onto Q28, pin # 1. This voltage should then reach pins 24 & 25 of the LVDS display connector.
            Check it.
            • Paul20
              • Jul 2022
              • 40
              • Italia
              #26
              Here are the updates.
              I connected pin #2 of Q28 to ground taken from pin #2 of C2.
              When the card is turned on, on pin #1 of Q28 I find 3.3V and consequently also on pins 24 and 25 of the LCD connector.
              The screen seems to want to start, but it stays black, not off, but it appears to be on but completely black.
              Against the light you can't see anything.
              The screen works perfectly, tested with a fully functional Motherboard.
              Something still seems to be missing.
              • mon2
                • Dec 2019
                • 14672
                You may be missing some other required signals to drive this display.
                Attach the same display to your other but working box.
                Measure the voltages on each LVDS connector pin.
                Then do the same for the non-working board.
                Post the readings so we can compare.
                • Paul20
                  • Jul 2022
                  • 40
                  • Italia
                  #28
                  Not working motherboard:
                  Pin 1, 2, 3 - 18.9
                  Pin 4 e 5 - NC
                  Pin 6 e 7 - 0
                  Pin 8 - NC
                  Pin 9 - 006
                  Pin 10 - 006
                  Pin 11 - GND
                  Pin 12 - 006
                  Pin 13 - 006
                  Pin 14 - GND
                  Pin 15 - 012
                  Pin 16 - 012
                  Pin 17 - GND
                  Pin 18 - 2,34
                  Pin 19 - 2,34
                  Pin 20 - GND
                  Pin 21 - 003
                  Pin 22 - 014
                  Pin 23 - 3,3
                  Pin 24 - 3,3
                  Pin 25 - 3,3
                  Pin 26 - 0
                  Pin 27 - 3,3
                  Pin 28 - 002
                  Pin 29 - 002
                  Pin 30 - GND
                  Working motherboard:
                  Pin 1, 2, 3 - 18.9
                  Pin 4 e 5 - NC
                  Pin 6 e 7 - 3,3
                  Pin 8 - NC
                  Pin 9 - 1,23
                  Pin 10 - 1,19
                  Pin 11 - GND
                  Pin 12 - 1,19
                  Pin 13 - 1,25
                  Pin 14 - GND
                  Pin 15 - 1,05
                  Pin 16 - 1,36
                  Pin 17 - GND
                  Pin 18 - 1,06
                  Pin 19 - 1,37
                  Pin 20 - GND
                  Pin 21 - 3,3
                  Pin 22 - 3,3
                  Pin 23 - 3,3
                  Pin 24 - 3,3
                  Pin 25 - 3,3
                  Pin 26 - 0
                  Pin 27 - 3,3
                  Pin 28 - 002
                  Pin 29 - 002
                  Pin 30 - GND
                  • mon2
                    • Dec 2019
                    • 14672
                    Pins 6 & 7 are LOW (0 volts) on the non-working board which means the logic board is requesting that the display remain OFF.
                    DISPOFF# has the '#' symbol which denotes an ACTIVE LOW signal. So if this line is LOW, the display will be OFF.
                    DISPOFF# is tied to BACKOFF# which is linked through R13 to the KB930QF (pin #104).
                    Confirm that R13 is present on the logic board.
                    Next step I think should be to reflash the KB930QF device. No experience in this area so wait on others to comment. Perhaps this controller has corrupted firmware.
                    I am assuming that your lid sensor is working since you can work with an external screen.
                    • Paul20
                      • Jul 2022
                      • 40
                      • Italia
                      #30
                      R13 I can't find neither on the diagram nor on the boardview in my possession, so I can't search on the motherboard, maybe we look at slightly different schemes.
                      BKOFF in my case is connected to R375 (not present on Motherboard) Pin 2 BKOFF pin 1 + 3VS.
                      BKOFF connected to KB930QF is on pin 105
                      If KB930QF needed reflash, I wouldn't be able to run it, as I don't have a programmer.
                      • mon2
                        • Dec 2019
                        • 14672
                        I have a very bad schematic for this logic board. My schematic lines are not aligned with the component symbol. More crapware.
                        Is your version of the schematic any better ?
                        Can you link or post it here if on the forum ? Want to be 110% sure we are referencing the same logic board.
                        • Paul20
                          • Jul 2022
                          • 40
                          • Italia
                          #32
                          My Motherboard is exactly that of the scheme I am using, same for the boardview.
                          If I can post it here on the forum, I do.
                          I simply downloaded it from the internet, but I don't want to risk infringing any copyright.
                          • maralexbar
                            How to force Acer Aspire Series to bootup BIOS/UEFI on external Monitor?
                            by maralexbar
                            I ask this question in general as there are many Acer Aspire models with UEFI Insyde BIOS that do not boot to the BIOS on an external monitor (VGA, HDMI, etc) showing only the Internal LCD (LVDS, eDP etc).
                            It's a pain to work on Acer notebooks with a broken screen and not being able to access the BIOS using an external monitor.
                            If anyone knows how to force the external monitor as primary for Notebooks of those models
                            11-02-2024, 09:18 AM
                            09-06-2024, 05:27 AM
                            Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                            This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                            09-07-2024, 05:00 AM
                            Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                            This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                            Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                            This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-07-2024, 04:10 AM
