Kindly identify this bios chip, Adesto AT25QF641 SUB
  • Awejire
    • Mar 2022
    • 24
    • Nigeria
    I believe this bios chip is currup so I'm trying to reprogram the chip but my programmer could not auto detect the chip. I want to know what type of chip to select to write it wit my programmer.
  • mon2
    • 14673
    Re: Kindly identify this bios chip
    Hi.
    1) Datasheet for this chip is attached.
    2) Datasheet notes that the device is compatible with a 3v3 power rail - so your programmer should be able to support this.
    3) Ignore the use of auto-detect since the look up table (database) is stale and appears to not support the IDs that are embedded inside this component.
    The reading of the IDs is JEDEC standard so EVERY FLASH chip on the market must allow for the same commands / same timing to read out the IDs inside the flash device.
    Confirm this detail that you can read out the IDs -> compare them to what is inside this datasheet. Do they match ?
    If not a match then the IC is defective or not seated properly inside your programmer tool.
    4) After the above confirmation, try a more common flash family from perhaps Winbond.
    Can your programmer be configured to ignore the ID ?
    That is, in the end, the programmer is spitting out SPI commands which are common to 99.999% of the flash industry. The programmer tool is only required to send out simple SPI commands -> to erase -> to read / write from a PC memory space.
    So it should be possible to read in the known good contents from a file into your PC -> allow for the programmer tool to erase this chip -> program the chip using standard SPI commands (using Winbond as an example) -> verify the contents.
    SPI is slower than QSPI (Quad SPI) but for this case, keep it simple.
    A number of years ago we tested a batch of different flash memory devices to see how fast we could program them using QSPI mode. Recall Adesto as a good brand that could operate at high data rates.
      • 21932
      Re: Kindly identify this bios chip, Adesto AT25QF641 SUB
      what model is your programmer and the software version
      • hotcrossedbuns999
        M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
        by hotcrossedbuns999
        My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
        1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
        2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
        3. I could only locate two chips that look like bios chips. Could someone verify this
        01-03-2025, 12:32 PM
      • BMCappelletti
        Asus Chromebox CN62 - wrong chip put on BIOS reader
        by BMCappelletti
        Long story short:
        - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
        - gave the computer to his son a couple years later
        - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
        - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
        (seems like the story was not that short)
        He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
        01-08-2025, 07:27 PM
      • inck243
        Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
        by inck243
        Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
        The BIOS...
        07-25-2024, 09:17 AM
      • Azurain
        Elitebook 840 G5 Bios Chip Soldering Question
        by Azurain
        I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
        Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
        04-14-2023, 06:58 PM
      • danielgerman681
        ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
        by danielgerman681
        Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
        08-27-2025, 01:17 PM
