Hp la-c701p no display
  • ahmarzo
    • Mar 2015
    • 171
    • india
    When i press power button there is voltage on ram coil for few seconds and power led restart and no voltage on ram coil.
  • mon2
    • 14369
    Re: Hp la-c701p no display
    See attached.
    Measure the voltages on the DCIN mosfets and post their readings.
    What is the history of the unit ? Any liquid damage ?
    Just started to fail one day under normal use ?
    Are you using the original power adapter ?
    • Udemzy
      • May 2017
      • 161
      • Guatemala
      Can you post the DC power supply reading?
      If there's voltage on the ram coil for some seconds before it goes off since you need the s4-s3-s0 then check accordingly.
      Check if the slp_s4#, slp_s3# and it corresponding voltage like the susp# etc is generating and also check your DC to DC section.
