help me, Dell 7567 compal la-d993p 1.6v on power button
  • luzvel64
    • Apr 2017
    • 103
    • Guatemala
    Hello, I am here to ask for help with a Dell inspiron 7567 laptop.
    having the cmos battery disconnected, the laptop turns on without giving a video signal, then turns off and doesn't turn on anymore, just disconnecting and reconnecting the charger.
    I have the sources of 3 and 5 volts_alw but only 1.6v arrives at the power button
    on RE31 which is +RTCVCC I have 3.0v but on the other side of RE31 which is POWER_SW_IN# I only have 1.6V
    RE31 is a 100k resistor, and it's ok.
    I found the schematic and the board view in this thread
    https://www.badcaps.net/forum/showthread.php?t=81570
    can someone help me to find the problem, i will be very grateful
  • mon2
    • Dec 2019
    • 14685
    Re: help me, Dell 7567 compal la-d993p 1.6v on power button
    Remove all power.
    Check the resistance to ground of RE31 (pin #2) on the side that is 1v6.
    What is the resistance reading ? Also post the scale used on the meter.
    • luzvel64
      • Apr 2017
      • 103
      • Guatemala
      Originally posted by mon2
      Remove all power.
      Hello, thanks for answering, I did it and there is no resistance
      • mon2
        • Dec 2019
        • 14685
        Configure the meter into diode mode.
        Remove all power.
        Red meter probe (yes red) to ground.
        Black meter probe to the same test point.
        What is the diode mode reading?
        • luzvel64
          • Apr 2017
          • 103
          • Guatemala
          Remove all power.
          I attach the readings
          • mon2
            • Dec 2019
            • 14685
            Diode reading is healthy.
            See attached.
            The same switch lead goes to this APS CONN. Can you remove the cable or connection to remove the load on the RE31 resistor ?
            Then check if the voltage level is restored or not @ RE31.
            • luzvel64
              • Apr 2017
              • 103
              • Guatemala
              See attached.
              In JPW I do not have the flex or the power button connected
              In JAPS there is no connector, only the pads.
              • mon2
                • Dec 2019
                • 14685
                So it sounds like it is coming down to the EC controller @ UE1.
                Wait on others to comment but it does not seem correct to have this lower voltage on an INPUT pin to the EC.
                Also, the VIO for this controller is 3v3 so 1v6 is not correct.
                You can try to remove CE12 (capacitor) and confirm if the voltage level changes.
                • luzvel64
                  • Apr 2017
                  • 103
                  • Guatemala
                  I have removed CE12 but it was still the same voltage 1.6.
                  I have removed RE47 and 3.0v has passed through RE31.
                  I have measured RE47 outside the motherboard and it shows 10k
                  I have 3.0V at ec pin 127
                  • mon2
                    • Dec 2019
                    • 14685
                    That is strange.
                    Remove all power and check the resistance to ground of RE47 (both pads). If RE47 does not go anywhere due to empty connectors on the logic board, it should not impact the final voltage @ RE31.
                    At this momemt, RE31 & RE47 are building a resistor based voltage divider.
                    • luzvel64
                      • Apr 2017
                      • 103
                      • Guatemala
                      I have changed RE47 and I already have 3.0v in the power button, and it already turns on and off from the power button.
                      Thank you very much for your help @mon2
                      • tipoti
                        • Oct 2015
                        • 35
                        • turkey
                          DELL Inspiron 7567 Notebook 7000 Specification for Upgrade or Repair
                          This specification for the DELL Inspiron 7567 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7567 boardview and 7567 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 7567...
                          09-06-2024, 08:01 AM
