HP Probook 450 G6
  • caprigtx
    • Mar 2022
    • 65
    • Netherlands
    HP Probook 450 G6
    Hi , can some use information to put me in the right direction , i am newby
    I got a HP Probook 450 G6 DAX8JMB16E0 Rev E .
    When i turn it on , i hear the fan spinning , but got black screen, also no picture thru HDMI .
    Mayby Bios . but also reprogrammed it , no result .
    Pls put me in the right direction , learning.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP Probook 450 G6
    Link the schematic/boardview,if available. Start by measuring voltage on all big grey coils when turned on.
    • caprigtx
      • Mar 2022
      • 65
      • Netherlands
      • caspian
        • Oct 2015
        • 1589
        • Laptop
        The 6.9v on the photo seems wrong. you might mean 0.9v.
        Have you really measured 6.9v on those two coils?
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Voltage on all coils seems correct if that 6.9V is 0.9V as @caspian has pointed out. The bios you flashed was with clean me or just any other dump sourced from net?? To me,it still seems like bios issue. What is the consumption on dc supply 01.With ram 02.Without ram??
          • usyusy
            • Sep 2021
            • 171
            • Pakistan
            Sir with ram if board gets hot and no display,without ram no hot and led blinks indicating of ram missing, what can be the issue
            • caprigtx
              • Mar 2022
              • 65
              • Netherlands
              Caspian is right , point in the wrong place Its 0.82
              • caprigtx
                • Mar 2022
                • 65
                • Netherlands
                With and without Ram 02
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  There can be n number of issues. When ram is not installed, mb doesnt rech S0 state,so will remain relatively cool as many rails dont come up. But thats not the point. You need to observe dc supply consumption in both scenarios-With ram/without ram. If the consumption is more or less same, it indicates mb is not reading ram. Often the cause is SDA/SCL bus though there can be other reasons.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    What do you mean ?? I couldnt understand.
                    • usyusy
                      • Sep 2021
                      • 171
                      • Pakistan
                      right sir, cpu section was getting hot, mb, i think, was reading ram (as without ram led was blinking), thank you for concept clearance.
                      • caprigtx
                        • Mar 2022
                        • 65
                        • Netherlands
                        I mean , voltage with ram or without ram stays the same.
                        If i connect the power the fan is spinning fast , and cpu is getting hot.
                        And caps is blinking 4 times.
                        • caprigtx
                          • Mar 2022
                          • 65
                          • Netherlands
                          I think Grapics controller not functiona.l
                          • vannix
                            • Mar 2018
                            • 74
                            • Italy
                            4 flashes can indicate a problem related to the initialization of the graphic controller as you say, although it's strange if the voltage on the gpu coil is correct.
                            Note that in the new bios there is a new blink code, and with 4.x flashes can also indicate a temperature (or sensor) problem. how many flashes/pauses do you see with and without ram?
                            Edit: have you tried another ram? remember that with the integrated gpu even a faulty ram can give an error on the graphics card
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              You mean voltage or current consumption?? Are you using a dc supply to power the machine or adapter??
                              • caprigtx
                                • Mar 2022
                                • 65
                                • Netherlands
                                Yes tryed other ram, same result.
                                • caprigtx
                                  • Mar 2022
                                  • 65
                                  • Netherlands
                                  I used adapter.
                                  • caprigtx
                                    • Mar 2022
                                    • 65
                                    • Netherlands
                                    I mean voltage
                                    • vannix
                                      • Mar 2018
                                      • 74
                                      • Italy
                                      Have you checked if there is signs of oxidation/water damage?
                                      The current draw test suggested by mcplslg123 would also be important if you can do it
                                      Check also this...
                                      • caprigtx
                                        • Mar 2022
                                        • 65
                                        • Netherlands
                                        Without ram it blinks 3x fast and 2x slow.
                                        No signs off any oxidation or water damage.
