SONY MBX 226 19V no post
  • Yosua
    • Jun 2021
    • 221
    • Indonesia
    hello all my colleagues, I want to ask for help to solve this mobo soni mbx 226, the case is 19v just stuck on the drain ac fet and it doesn't want to spread, I've tried to replace the acfet but the case is the same, and I've also replaced the charger ic it's still the same , after I measured the ACDET pin on the charger ic bq24753a it only outputs 1.04v voltage, and I've measured the resistance on the 2 pulldown resistors on the acdet line and they are normal
    can anyone give me advice?
  • mon2
    • 14666
    Re: SONY MBX 226 19V no post
    Measure the voltage at the fuse, both sides of the dc adapter.
    Also the voltage of DC_IN @ PR28, pin #1.
    Post each measurement. Use 20v or higher DC mode scale.
    • Yosua
      • Jun 2021
      • 221
      • Indonesia
      thank you for your little time sir, and for both sides of the fuse have the same voltage 19v
      this is for PR28 . measurement
      pin1 : 19v
      pin2 : 1.04v
      • Yosua
        • Jun 2021
        • 221
        • Indonesia
        I forgot to say that on my multitester the 19v voltage that appears is (-), even though my probe is not reversed.
        • mon2
          • 14666
          This is not correct if indeed you are with RED meter probe on the 19v DC adapter pin; black to ground.
          Is the DC adapter the original ? Or is it a universal adapter where the tip can be rotated ?
          From the description, the adapter may have the tip reversed.
          Remove it and check the DC adapter directly to see if the polarity is correct or not.
          A proper adapter should show +19v at the fuse and also at the pin #1 of the ACDET voltage divider resistor pair. Then if the resistors are of the proper value, the voltage at the common junction = ACDET should be > 2v4 and this informs the charger IC that the adapter is worthy of powering this logic board.
          • Yosua
            • Jun 2021
            • 221
            • Indonesia
            I only use a universal dc power supply, sir, later I will try with the original charger, while for the PR28 yesterday I measured the resistance:
            430k : regardless of board
            251k : mounted on the board
            • mon2
              • 14666
              1) I think the polarity of your universal power supply is reversed. Confirm it before proceeding and better to use the original power supply.
              2) After the above -> check ACDET again. It should be a better reading and > 2v4.
              3) If ACDET is not correct, remove all power and check these 2 resistors again. Carefully remove off the board with flux and check their values while out of circuit. The resistance is critical to dial up the proper trigger voltage for the ACDET signal. If the final voltage of ACDET is under 2v4, the charger will disable the first DCIN mosfets.
              • Yosua
                • Jun 2021
                • 221
                • Indonesia
                ok sir, later i will try to use the original dc adapter, then i want to ask,
                does it mean the board is in trouble, when the resistor is detached from the board the value is normal, but when the resistor is attached its value drops
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Perhaps 'coz your dc supply voltage is set at higher then 19V and multimeter is not able to read it. Change your multimeter to 200V and perhaps it will show correct reading.
                  • Yosua
                    • Jun 2021
                    • 221
                    • Indonesia
                    sorry I just got back to this message, the result is still the same even though I use the original adapter sir and it's still -19v
                    • Yosua
                      • Jun 2021
                      • 221
                      • Indonesia
                      I use 200v mode the result is still the same sir
                      • mon2
                        • 14666
                        Can you post a picture of your meter to show how you are taking this measurement ?
                        Red meter lead on the point to test; Black meter lead to ground (shield is ok) on the logic board.
                        You should not have -19v as a reading.
                        • Yosua
                          • Jun 2021
                          • 221
                          • Indonesia
                          you are right sir, it turns out that there is a problem with the dc cable, now the voltage is + 19v, but the problem is not over, 19v stops on the second fet, and the gate on the 19v fet
                          • Yosua
                            • Jun 2021
                            • 221
                            • Indonesia
                            and I also made a mistake, I forgot to remove the adapter when I replaced the bq24753 ic
                            • Carlos#2003%
                              Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                              by Carlos#2003%
                              Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                              02-15-2024, 07:52 PM
                            • dkneyle
                              Sony KDL-46HX850 Can't upgrade/update firmware
                              by dkneyle
                              Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                              Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                              09-25-2024, 10:44 PM
                              Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                              This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                              09-06-2024, 05:27 AM
                              Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                              This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                              09-06-2024, 05:30 AM
                              Sony VAIO SV-T1122F4E Hybrid (2-in-1) Tap 11 Specification for Upgrade or Repair
                              This specification for the Sony VAIO SV-T1122F4E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SV-T1122F4E boardview and SV-T1122F4E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
