Model
ell Inspiron 5520
MB:LA-8241P(Discrete)
Problem Description:
It works perfectly fine with adapter.
Battery charging is fine.
Doesnt give display with battery only(It triggers from battery alone but nothing on screen as it doesnt post.
Works fine with Adapter+battery connected but the moment you remove adapter, there is garbage like display on screen for few seconds and then it shuts off.
Voltage on all coils are present on battery also and they are exactly identical when working with adapter. So no voltage drop on coils.
Battery is 100% ok and its not graphics issue.
I've solved the case but will like you to scratch your head a bit on how to solve this problem.
COMMENTS/IDEAS SHOULD BE GIVEN BY FRESHERS ONLY as experienced members can solve it own their own in few minutes.
PS: Will share the solution if and only if you make an honest attempt to solve it.
ell Inspiron 5520MB:LA-8241P(Discrete)
