Asus 701SD_MB REV 1.0G NEED HELP.
  • Gau_saha
    • Feb 2020
    • 35
    • India
    Sir,
    Need badly the schematic of Asus 701SD_MB REV1.0G.
    The board is having no display .
    Pls share the schematic if anyone have it .
  • mon2
    • 14370
    Re: Asus 701SD_MB REV 1.0G NEED HELP.
    Hi. Asus schematics are rare.
    What is the history of this unit ? Power adapter is good ?
    Do you see the DCIN voltage?
    Review where the DCIN voltage enters the logic board -> then likely 2 mosfets will follow. Check if the same DCIN voltage is present on the mosfet pins.
    Post the SMD markings of the mosfets. Also, nearby should be a charger IC that controls these 2 mosfets - what are the markings on the charger IC.
    Be very careful when checking the voltages on the mosfet as the power is live and use good meter leads. If not possible, do not proceed.
    Instead, we can do resistance measurements to check if the mosfets are good or defective.
    • Gau_saha
      • Feb 2020
      • 35
      • India
      Thanks Sir for giving me advice .I will let u know .
      • Udemzy
        • May 2017
        • 161
        • Guatemala
        Since you're having no display issue, check all coil impedance first.
        Then power it on and check if voltage is available on coils,your dc reading should give you a clue. Check DC/DC section, if vcore is not available you can get the datasheet online and check it basic requirements.
        Sometimes writing a new bios file will resolve the issue.
        • Gau_saha
          • Feb 2020
          • 35
          • India
          Thanks Sir .
