Asus X756UQK throttling
  • reformatt
    • Feb 2020
    • 1510
    This machine was a donation to a guy I do board repairs for. It wasn't working so asked me to take a look at it. Some weird stuff on this one so wondering if anyone else has any experience on them? On the top panel it says it's a F756U, however the board says its a X756UQK.
    So I found 19V on one of the coils, which was a shorted high side MOSFET. Was QM1830M, replaced with a AON7502. Thought game over, but this turned out to be the battery charger (no schematics or boardviews). Board working...some corrosion noted in a few spots but nothing too major.
    Now something weird is that someone had removed the internals of the battery leaving only the controller. I only had a glance at it, but someone had jerry rigged a 7806 3 pin regulator in there. Maybe to fool the system into thinking it has a working battery?
    Anyway running off my bench supply and no battery, the CPU is throttled to its slowest speed. Can disable BD PROCHOT using Throttlestop and system runs at full speed, and CPU temps are normal. Using the Intel Xtreme Tuning utility, this indicates Thermal Throttling.
    So if anyone has any experience with this model, does in throttle if you don't have a battery or non-genuine charger? Don't know if it's worth him spending the money on parts etc since I don't have any schematics etc to troubleshoot it.
  • mon2
    • Dec 2019
    • 14677
    Re: Asus X756UQK throttling
    Hi. Review the charger IC and then the datasheet, if available for that component.
    What is the part # on this IC?
    Check if ACOK PIN is high or not with the adapter.
    The external LDO sounds like a desperate hack.
    Attempt to stabilize without the battery and hack circuit.
    I am not aware any special identification circuits for the Asus adapters. If your power supply can support the current to mimic the original, it should work.
    • reformatt
      • Feb 2020
      • 1510
      It's a BQ24780S. PROCHOT is open drain, active low and this is reading 5V. So PROCHOT isn't being asserted by the charger IC, must be coming from elsewhere. My other thought was no fan tach, but this is reading fine in the BIOS setup screen.
      Runs fine with Throttlestop so I'll leave it up to old mate to decide if he resells it.
      • Jo3nokokok
        Prochot Ext Asus m409da
        by Jo3nokokok
        Can someone help me.
        I have asus m409da or x409da amd ryzen 3 3200u
        The problem originate from bad cooling, from start its already overheating a lot booting windows causing it to reach 100°C
        And the fan started to fail and i kinda moded the laptop with older laptop fan, its not great but get the jobs done
        And after some time, my relative use the laptop and last time i used it it still great but idk the specific.
        But the person that use this laptop start telling me like the battery was starting to go bad etc2 and now i exchange the...
        07-17-2025, 12:09 AM
      • flat-earther
        ASUS X54H laptop thinks it's always charging even with charger unplugged
        by flat-earther
        The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
        Windows also shows ''Plugged in'' when charger is not connected.
        This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
        Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
        If I let battery run out and say it has 3% Windows will...
        06-24-2025, 09:32 AM
        ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook CX1 Specification for Upgrade or Repair
        This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
        09-07-2024, 02:50 AM
        ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
        This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
        ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
        This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
