Lenovo X1 Carbon 2. Gen no Display!
    Notebooks is powering on without post.
    All power rails present, only L1 (Vcc_CPU_Core) measurement 0,112 V (resistance on L1 120 ohm).
    Flashing New bios no different.
    Mainboard: LMQ-1 MB 12298-2 48.4LY07.021
    Re: Lenovo X1 Carbon 2. Gen no Display!
    Hi, have you checked all voltages on the U16 chip to see if they are all good?
      L1 #pin2 CPU side one leg desoldered and u16 measurement are like this:
      Pin1: 0V
      Pin2: 0V
      Pin3: 1,8V
      Pin4: 1,8V
      Pin5: 0,8V
      Pin6: 1,8V
      Pin7: 1,7V
      Pin8,9,10,11: 5,1V
      Pin12,13,14,15: 0,5V
        reflow ram chips with a hot air station, had one doing the same thing and that was the only fix that worked for a while. the ram failing are a common issue with the gen2 x1 carbons
          Reflowing RAM usually won't fix it, it will fail again shortly after. Problem appears to be CPU-related.
