820-00165-A No Mouse No Keyboard On OSX works On Ubuntu?
  • macattack600
    • Aug 2011
    • 97
    820-00165-A
    In mac osx there is no keyboard no kb backlight or mouse.
    But if I boot into usb ubuntu everything works just fine. If I boot into usb installer of diff mac os version it gives the mouse and keyboard sign so I know its not the drive.
    I tried the decrypt drive I saw on youtube but that didn't work.
    I tested the connector on pin 10 14 and 20 all have normal voltage.
    Sort of stumped here.
    I will throw out that this board had no screen backlight I replaced q7707 and Driver IC and it is fixed , is there some possibility that it also caused short along lines of keyboard backlight?
    The keyboard backlight and the mouse and keyboard all worked when I tested with external monitor before I fixed the screen backlight issue with the same drive i'm using.
  • reformatt
    • Feb 2020
    • 1419
    Re: 820-00165-A No Mouse No Keyboard On OSX works On Ubuntu?
    Does a PRAM reset work from power up? This is the first thing you should try. If it's working in recovery mode or off a USB installer, you should try a spare SSD and install Big Sur or Monterey and see the result.
    You could try reinstalling MAC OS from recovery mode on the customers SSD if that resolves it. However, I don't offer to upgrade a customers MAC OS, since anything beyond Catalina will disable 32 bit apps (such as old versions of Office). So I'd just be reinstalling whatever version they have.
    • macattack600
      • Aug 2011
      • 97
      Definitely tried the Pram and SMC reset but nothing changed.....Got ahold of another topcase , it was either the trackpad ,tp cable or the keyboard.
      The Mac is fully working .
      Its strange it worked with Ubuntu. I'm leaning more to it being the trackpad was bad because the cable was unkinked and perfect? At one point I was able to boot into a older os version via usb and the keyboard lit up but still no mouse , no cap lock .
      Thank you always for your help reformatt!!
