Asus x541UV no power
  • zolie
    • Jun 2015
    • 52
    • Hungary
    I'd like to fix it and ask for help here. The error: cannot be turned on.
    PQ8901 (QM3056M)
    D: 19V S: 0V G: 0V
    If I shorted D and S, it will start and run continuously until I turn it off. I guess the gate won't open because it won't get anything. Can anyone help me solve this error?
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Asus x541UV no power
    https://www.badcaps.net/forum/showthread.php?t=90356
    • mon2
      • Dec 2019
      • 14010
      Post the markings of the this and the next mosfet that follows this one.
      Post the markings on the charger IC that is linked to these 2 mosfets.
      Then remove all power. No battery, no adapter. Meter in resistance mode (2k scale or similar).
      Check and post the resistance for the first mosfet:
      Source (1-2-3) and drain (5-6-7-8)
      Source (1-2-3) and gate (4)
      Gate (4) and drain (5-6-7-8)
      Searching for any low resistance reading which will likely mean the mosfet is defective.
      Repeat with the 2nd mosfet.
      Post your resistance values.
      If the resistance is more than the meter scale, the meter should show OL (over limit). This is ok. You can then change the meter scale to the next higher scale till there is a good reading.
      • zolie
        • Jun 2015
        • 52
        • Hungary
        M3056M
        S-D:0.510 k
        S-G:0.373 M
        G-D:0.922 M
        M0930M
        S-D:0.525 k
        S-G:0.375 M
        G-D:0.7 M
        BQ24780S
        • mon2
          • Dec 2019
          • 14010
          Mosfet resistance readings look ok.
          Still with no power to the board, meter in resistance mode, check the resistance to ground for the drain (5-6-7-8) of each mosfet. Repeat for the source pins (1-2-3).
          Checking for a low resistance which may be due to a shorted capacitor. Post the measurements.
          If the readings are not low, then continue.
          Carefully, very carefully, measure and post the voltage readings of each pin of the charger IC. Do not short pins with the meter probe which can damage the charger IC.
          Meter in DC 20v scale.
          Red meter probe on the pin to measure, black meter probe to ground (shield is ok).
          Post the voltage readings.
          • zolie
            • Jun 2015
            • 52
            • Hungary
            M3056M
            D-GND: 108k
            S-GND: 0.370M
            M0930M
            D-GND: 2.890M (the value is slowly increasing)
            S-GND: 0.430M (the value decreases continuously)
            Is the charging IC still without voltage? I'll continue soon.
            • zolie
              • Jun 2015
              • 52
              • Hungary
              I could only measure it now.
                ASUS VivoBook X541UV-GO1002T Notebook Max Specification for Upgrade or Repair
                This specification for the ASUS VivoBook X541UV-GO1002T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X541UV-GO1002T boardview and X541UV-GO1002T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                09-06-2024, 08:00 AM
                ASUS VivoBook X541UV-GQ1214 Notebook Max Specification for Upgrade or Repair
                This specification for the ASUS VivoBook X541UV-GQ1214 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X541UV-GQ1214 boardview and X541UV-GQ1214 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                09-06-2024, 06:24 AM
                ASUS VivoBook X541UV-GQ1473 Notebook Max Specification for Upgrade or Repair
                This specification for the ASUS VivoBook X541UV-GQ1473 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X541UV-GQ1473 boardview and X541UV-GQ1473 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                ASUS VivoBook X541UV-DM1393 Notebook Max Specification for Upgrade or Repair
                This specification for the ASUS VivoBook X541UV-DM1393 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X541UV-DM1393 boardview and X541UV-DM1393 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                09-06-2024, 06:20 AM
                ASUS VivoBook X541UV-GO1352T Notebook Max Specification for Upgrade or Repair
                This specification for the ASUS VivoBook X541UV-GO1352T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X541UV-GO1352T boardview and X541UV-GO1352T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                09-06-2024, 06:19 AM
