Ideapad Yoga 3 14" - help with repair.
  • petr.hlavacu
    • Nov 2020
    • 11
    • CZ
    Hi, i have a Lenovo Ideapad Yoga 3 (14", i5-5500U, board NM-A381). It only light up power led (no screen, fan spin, nothing). I found shorted mosfet on vcore rail. After replaced the mosfet its turning on. Fans spins up and down according to temps but still no screen. I found the coil next to replaced mosfet warm up, then getting hot. I measured the coil and it seems fine.
    Can anyone advise where to continue to look for a fault?
    PS: Sorry for my bad english.
    EDIT: Vcore voltage seems fine.
  • pavithra_uk
    Optiplex 3050 Vcore Mosfet short
    by pavithra_uk
    it is 3+2 vrm
    vcore high side mosfet (AON6380) shorted when turned on instatly killed the processor (i5 7400)
    gate drive chip (NCP81166) also gone.
    any suggestions before replace mosfet and gate drive chip? what if I replace 3 high side mosfets with more current capable mosfets?
    odd question:
    what if I put two silicone diodes series in forward way? assume each diode 0.7v drop and total of 1.4V. vcore not exceed this but can protect cpu from direct 12V hit from shorted mosfet ?...
    10-21-2025, 11:32 AM
  • jm942
    Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
    by jm942
    My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
    I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
    I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
    I did voltage injection on the cpu with 0.7V and i have a current...
    07-11-2024, 05:11 AM
  • ebyte64
    Lenovo IdeaPad 330 laptop mosfet issue
    by ebyte64
    Good day everyone.
    I have been scratching my head with a Lenovo laptop I got in today.
    The laptop had no power and taking no amps from the power supply. Checking voltage showed 20v only on one side of the first mosfet. Took it off and replaced it and then same story. Took off second mosfet and then the first mosfet had the right voltages as well as 25v on gate is it should. Replacing the second mosfet the problem started again.
    Even using a wire to bypass the second mosfet does the same interference with the first mosfet.
    Would anyone...
    06-27-2023, 10:19 AM
    Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
    This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
    09-07-2024, 05:20 AM
    Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
    This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
