Lenovo Y530 shuts off after few seconds
  • unimatrix93
    • Oct 2021
    • 347
    • Magyarország
    Hello and happy new year everyone!
    I have a Lenovo Y530 (NM-B701 rev1) notebook with a frustrating problem.
    It's shuts iftself off after pressing the power button. I have no POST screen, only power led and keyboard light. Same symphtomes on AC and on Battery.
    Things I tried:
    - General cleaning and repasting, reseating RAM modules
    - Reset CMOS
    - Reprogram BIOS with a programmer.
    - Checking main rails with Multimeter.
    Only suspicious thing I found was that the dual MOSFET on the 20V rail had 25.5V, so I replaced this two mosfets with new ones, but the 26.5V is still there.
    Could it be the culprit?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Lenovo Y530 shuts off after few seconds
    If the MOSFET is n channel, gate voltage should be higher. So 26v seems correct there.i think they are connected to charging circuit.
    • unimatrix93
      • Oct 2021
      • 347
      • Magyarország
      Thanks for clrafying!
      That's makes sense.
      I guess I check on the other MOSFETs too, there must be a short somewhere.
      • unimatrix93
        • Oct 2021
        • 347
        • Magyarország
        UPDATE
        So I tested the MOSFETs and I found something fishy on the +5VALW circuit.
        There are 3 MOSFET on this line named QV11, QV29 and QV12:
        QV11 - LBSS139WT1G - N-Channel
        QV29 - AO3402_SOT-23-3 - N-Channel
        QV12 - AO3402_SOT-23-3 - N-Channel
        I tested these MOSFETs by setting my MM in diode mode and I measured S (red probe) to D (black probe) then reversing the probes.
        First valuer is Red on S Black on D second is reversed.
        QV29: 0.010V / 0.010V
        QV12: 0.273V / 0.510V
        QV11: 0.518V / OL
        QV29 and 12 looks faulty since shouldn't it read openloop on reversed polarity like on QV11?
        I attached a photo of the parts and the circuit.
        I really hope I'm on the right track finally.
        • mon2
          • Dec 2019
          • 14240
          Place your meter in resistance mode (2k scale is ok).
          Measure and post the resistance for the following:
          Source & drain
          Source & gate
          gate & drain
          for each mosfet.
          • unimatrix93
            • Oct 2021
            • 347
            • Magyarország
            Here is the values:
            QV11:
            S-D:0
            S-G:0
            G-D:0
            QV12:
            S-D:0.276
            S-G:0
            G-D:0
            QV29:
            S-D:0.005
            S-G:0
            G-D:0
            • mon2
              • Dec 2019
              • 14240
              Desolder QV11 off the logic board and perform the same resistance checks on the removed part while it is on the lab bench. Do not power on the logic board with the part removed.
              Do you still have the 0 ohm resistance readings ?
              From the posted values, I would consider to replace each of these mosfets.
              Reference - see the resistance table for mosfets here:
              http://electronicsbeliever.com/how-t...-is-defective/
              • unimatrix93
                • Oct 2021
                • 347
                • Magyarország
                Thank you for your reply!
                I will desolder QV11 tomorrow and test it off circuit and I will also order a new MOSFETS... hope they are in stock.
                Will report back tomorrow with the results!
                • piernov
                  • Jan 2016
                  • 4435
                  • France
                  Resistance measurements don't make sense. Diode mode measurements are as expected. Components are unrelated to +5VALW circuit.
                  • unimatrix93
                    • Oct 2021
                    • 347
                    • Magyarország
                    UPDATE
                    So I desoldered QV11 and also QV29 because I measured short between source and drain with the continuity test.
                    Here are the values off circuit:
                    Resistance QV11:
                    S-D:0
                    S-G:0
                    G-D:0
                    So essentially the same as onboard.
                    QV29 also has the same readings, the short is still present on S - D.
                    Shall I proceed to order the new parts?
                    If yes, I wonder If I can swap AO3402 with AO3400?
                    I asking because only the latter is avaible at the local distributor.
                    I also cannot find QV11 (LBSS139WT1G) in stock...
                    • mon2
                      • Dec 2019
                      • 14240
                      What are the settings for your multimeter for these tests ?
                      Can you post a pic of the multimeter ?
                      • unimatrix93
                        • Oct 2021
                        • 347
                        • Magyarország
                        Sure take a look
                        Resistance set to 2kOhm as you recommended:
                        Diode mode:
                        Continuity mode:
                        • mon2
                          • Dec 2019
                          • 14240
                          Ok - that makes much more sense. The OL means 'over limit' - not 0 ohms.
                          OL means that it is now ok to select a higher scale till you have a proper reading. Please do this and post the values.
                          This also means, as noted by @Piernov, that the mosfets are most likely OK
                          Please post again with a higher scale on your multimeter.
                          • unimatrix93
                            • Oct 2021
                            • 347
                            • Magyarország
                            Sure, so I tested QV11 and I managed to get a values of these:
                            S-D:3.5Mohm
                            S-G:0
                            G-D:0
                            • mon2
                              • Dec 2019
                              • 14240
                              For the same removed QV11 mosfet,
                              lower the resistance scale on your meter till you can read a value.
                              If you indeed have 0 (zero) ohms in the lowest scale (2k ?) - then the mosfet is shorted. If you see 'OL' (over limit), then the next higher scale on the meter should be used for the measurement.
                              Confirm once again.
                              • unimatrix93
                                • Oct 2021
                                • 347
                                • Magyarország
                                Sure, I just tested it with QV11 mosfet:
                                From lowest (200ohm) to 2Mohms I get OL. Only on the highest setting which is 200Mohms can I get a reading which is 3.5Mohm S-D.
                                • mon2
                                  • Dec 2019
                                  • 14240
                                  This mosfet is ok.
                                  Repeat the testing with the other mosfets. You do not need to remove them off the board unless the reading is very low using the 200 ohm scale on the meter.
                                  • unimatrix93
                                    • Oct 2021
                                    • 347
                                    • Magyarország
                                    Okay!
                                    I will report back tomorrow with the results.
                                    Is the short on QV29 means something?
                                    • unimatrix93
                                      • Oct 2021
                                      • 347
                                      • Magyarország
                                      Hello, here is the results
                                      QV29:
                                      S-D: 1.997 (2kohm)
                                      S-G:0L (All scale)
                                      G-D:0L (All scale)
                                      Diode mode:
                                      Positive to S Negative to D: 0.042V
                                      Negative to S Positive to D:0.036V
                                      Continuity:
                                      Beeeeeeep on Source to Drain.
                                      QV12:
                                      S-D: 1.997 (2kohm)
                                      S-G:60 and increasing (on 200k)
                                      G-D:60 and increasing (on 200k)
                                      Diode mode:
                                      Positive to S Negative to D: 0.272V
                                      Negative to S Positive to D: 0.505V
                                      • unimatrix93
                                        • Oct 2021
                                        • 347
                                        • Magyarország
                                        Another Update
                                        I was checking the mosfets around the CPU and GPU and I found shorts on these devices:
                                        All of them has:
                                        S to D
                                        D to Ground
                                        S to Ground
                                        Resistance is very low between S - D and between S to Gound and S to Drain too.
                                        Only the mosfets that are placed horizontally have these values.
                                          Lenovo Legion Y530 Notebook Specification for Upgrade or Repair
                                          This specification for the Lenovo Legion Y530 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Y530 boardview and Y530 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo Legion Y530...
                                          09-06-2024, 02:30 PM
                                          09-06-2024, 01:21 PM
                                          09-06-2024, 12:51 PM
                                          09-06-2024, 11:35 AM
                                          09-06-2024, 11:32 AM
