Fujitsu Lifebook E544
  • matusiq
    • Dec 2020
    • 58
    • Slovakia
    Hello there peeps,,
    I am having strange problem with this notebook. Sometimes I am not able to turn this notebook on again. Only for a second the leds lid and then I am having the WIFI LED flash like for 5 times ,, sometimes only for 3 times. After maybe 5-10 minutes later I am able to power it on again.
    I have thermal cam and I have noticed when I plug the notebook in on the picture circled red you will notice TPS51125A which will heat up. When the power on failing I can see that it is getting cold again and after few seconds 3-5 later it will heat up again.
    Could this be the problem ?? As there is no schematic not really sure what to check. Thank You in advance...
    Flashed the BIOS with new BIOS and CleanME thinking that it will solve the problem but same thing was happening. Also was starting the board without the board where the switch is in case that is causing the problem. Same result ...
  • matusiq
    • Dec 2020
    • 58
    • Slovakia
    Re: Fujitsu Lifebook E544
    Nobody got any idea about this problem ??
    • Sephir0th
      • Oct 2020
      • 1283
      Check all Pins to GND. Usually each measurement should be in KiloOhms range. If everything seems fine, the issue might be behind a load switch, or the load-switch itself
      FairRepair on YouTube
      • matusiq
        • Dec 2020
        • 58
        • Slovakia
        Thank You for reply ... I will check it later on as this notebook is a little bit nightmare do disassemble and it taking a lot of room on my tabel.
        Like I said this problem is sporadic ... first turn ON when everything is cold is fine. After I will shut it down then the problem occur but after 5-10x it will start again ...
        Load switch meaning mosftet ???
        • Artuha
          • Mar 2018
          • 25
          • Latvia
          Originally posted by matusiq
          Hello there peeps,,
          Check resistance on coils near this chip
          • matusiq
            • Dec 2020
            • 58
            • Slovakia
            Well ... I can confirm that in my case replacing the chip "TPS51125A" solved the problem so far the notebook will turn on always without any problems.
              Fujitsu LIFEBOOK E544 Notebook E Specification for Upgrade or Repair
              This specification for the Fujitsu LIFEBOOK E544 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E544 boardview and E544 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Fujitsu LIFEBOOK...
              09-06-2024, 07:29 AM
              09-06-2024, 05:27 AM
