LA-9104P 7 beeps no video (inspiron 3521)
  • cpt.charlie
    • Sep 2013
    • 270
    • Spain
    Hi folks, happy new year!
    I'm trying to fix this dell that turns on but it gives no display, just 7 beeps (CPU related code), visual inspection didn't reveal anything significant, after some measures i discovered that the board is generating all voltages except +VCC_CORE and VCC_GFXCORE_AXG this voltages are generated by the same IC PU700 checked the IC and VR_ON is high and the chip gets proper 5V power.
    I thought the chip was defective and replaced it, to my surprise i got the same result with the new chip oops! checked the mosfets and seem OK, the resistance on the coils is about 4.3 ohm, then i checked the control signals comming from the processor VR_SVID_CLK, VR_SVID_ALRT#, VR_SVID_DAT all the signals are at 1.05v but no data transmission on the lines just steady voltage, for some reason the CPU is not sending the control commands, just in case i reflashed the bios chips (but not the EC as i don't have a suitable programmer) and nothing changed. PLT_RST# remains at low value but this signal can be controlled by EC and PCH, any idea for a proper diagnose without having to replace these chips?
    Thanks in advance.
  • mon2
    • Dec 2019
    • 14258
    Re: LA-9104P 7 beeps no video (inspiron 3521)
    https://www.youtube.com/watch?v=q5LpXlSeDxA
    • cpt.charlie
      • Sep 2013
      • 270
      • Spain
      Hi nom2, in my case 1.5v is present and the mosfet works just fine, my problem seems to be a bit more tricky.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Are you getting 1.8V at PL400?Next check PU500,Pin1 & PU600,pin4 for powergood signal. Remember, this mb has PG from one ic as enable for the other Like PG of pu500 enables PU600 and so on. So just check all the powergood and you will be able to solve the problem. I've repaired more then 30 boards of LA-9104P for 7 beeps. the reason are always not same but basics remain same. Another thing to watch is 1.5V at UZ1.
        • cpt.charlie
          • Sep 2013
          • 270
          • Spain
          Hi, i've checked all the power supplies and except PU700 all PSU are working fine.
          PU200 (3.3v and 5v) OK --> Pgood pin 23 =5V
          PU300 (1.5v and 0.75v) OK --> Pgood pin 10 =0V not connected
          PU400 (1.8v) OK --> Pgood pin 4 =0.5V not connected
          PU500 (1.05v) OK --> Pgood pin 1 =3.3V
          PU600 (0.9v) OK --> Pgood pin 4 =3.3V
          UZ1 also works fine.
          • Spider1211
            • Oct 2019
            • 532
            • Mauritius
            Try a known good BIOS. I had a similar issue once, 7 beeps and everything else seemed OK. Flashing a known good BIOS worked for me.
            • cpt.charlie
              • Sep 2013
              • 270
              • Spain
              I have tested 2 bios with the same result, unfortunately i can't flash the EC.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Do you have a dc power supply? If yes, then what is the consumption on your dc supply
                01. With ram
                02. Without ram
                DRAMRST# present on pin30 of ram slot??
                • cpt.charlie
                  • Sep 2013
                  • 270
                  • Spain
                  Hi mcplslg123, the current consuption with ram (and no fan) is 122mA with peaks of 135mA, without ram it remains at 119mA, pin 30 on both cases is 0.34V, i've checked QC2 and all i get is 3.3v on gate and 0V on drain and source, however none of these lines are shorted to ground, RC108 and RC110 are 1K and i have the expected 1.5v at RC108.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Current consumption at 122mA indicates a lot of rails are not coming up. So do check which coils are having no voltages and post here.Check all dc-dc transfet like QZ1/3/7 and UZ1(Page35 of schematic). Measure voltage at PIN1/4/5 of all these 4 mosfets (mb turned on) and post it here.
                    • cpt.charlie
                      • Sep 2013
                      • 270
                      • Spain
                      In fact the only missing voltages are +VCC_CORE and VCC_GFXCORE_AXG i no longer have the board as i returned it to it's owner, the low current i think it's caused becouse the chips were in reset state, thaks everyone for the help.
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Often the cause of low consumption on this mb is QZ3 which transfer less then 3.3V to PCH. Anyway , no point discussing it since mb is no more with you.
                          HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                          This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                          09-12-2024, 02:00 PM
                        • jeewantha
                          Dell Inspiron 3521 7 Beeps
                          by jeewantha
                          Motherboard - VAW00 LA-9104P
                          Rev:1.0(A00)
                          Board power on with 7 beeps
                          No Display
                          I checked All voltages
                          +VCC_CORE not present.
                          I changed PU700, Reprogram Bios but still same.
                          Anyone can give help to repair this.
                          02-12-2022, 03:05 AM
                          DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                          This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                          09-12-2024, 03:36 PM
                          DELL Inspiron 5680 Inspiron 5000 i5-9400 Specification for Upgrade or Repair
                          This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                          09-12-2024, 02:20 PM
                          DELL Inspiron 3471 Inspiron 3000 G5420 Specification for Upgrade or Repair
                          This specification for the DELL Inspiron 3471 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3471 boardview and Inspiron 3471 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                          09-12-2024, 02:15 PM
