Samsung la-8862p power problem
  • doctormasry
    • Dec 2019
    • 108
    • giza
    Hi friends
    i have problem in laptop samsung qcla4 la-8862p
    turn on 3 second and shutdown
    there are 3.3 AND 5 VOLT present
    led charge is ok
    Q29 D= 3.3 V G=0 S=0 SAME Q30 D=5 SAND G = 0 V
    steps
    flash tow bios is no new
    check ec on pq334 pin 2 = 3.3 pin 1 = no volt
    check pr339 is good
    any help
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Samsung la-8862p power problem
    If 3.3 and 5V is present on coil, there is nothing wrong in in PQ334 as if it is not working ENTRIP1/2 will not generate and you simply cant have voltage on coil. Focus on Q10Q11 working.
    • doctormasry
      • Dec 2019
      • 108
      • giza
      thanks @mcplslg123
      i check q10 and q11 and changed it but no new
      and i forget pch_pwr_En out from kbc sio but capacitor over chip no 3.3v
      thanks again
      • doctormasry
        • Dec 2019
        • 108
        • giza
        i removed q10 lap top turned on power ok but no display
        i must change q10 same numaber
        • victor_quiroga
          • 62
          • argentina
          Thanks!
            09-07-2024, 05:50 AM
          • howardc64
            Samsung UN55JU650DF network/streaming problem
            by howardc64
            Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
            This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
            07-09-2025, 12:44 PM
          • alro7779
            Samsung UN55MU6103F video problem; has colored stripes on the display
            by alro7779
            Hello, everyone!
            A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
            09-27-2025, 11:29 PM
            09-06-2024, 11:40 PM
