dell latitude 7490 la-f322p no power
  • kjchatman
    • Dec 2012
    • 209
    • united states
    this board does not seem to have a short to ground. 19 volts gets to the current sensing resistor. 12 volts is on the battery terminal. there is 0v on the battery smbus but i don't have a battery for it and that might be the issue. will someone tell me whether this board needs a battery installed to power up?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: dell latitude 7490 la-f322p no power
    Nope. All laptop mb will work in ac adapter mode(without battery).So to powerup, battery is not needed.Btw, if you have 0 volts on smbus that indicates perhaps absence of 3v LDO. So do check your 3V PWM regulator's requirements and measure the resistance on 3V LDO.
    • kjchatman
      • Dec 2012
      • 209
      • united states
      gettin 0v on 3v5v_en with comes from alwon. what is alwon
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        ALWON=Always On. This signal comes from SIO and is needed to get output on 3/5V coils. But first you need to get 3V LDO. The PWM regulator will generate it without ENABLE signal.
        What is the voltage and resistance on 3V LDO??
        • kjchatman
          • Dec 2012
          • 209
          • united states
          the sio which is a bga package appears to the issue. rtc_cell has a short to ground and i ran 1v through its path and the EC lit up like a christmas tree on the thermal camera. i would reball it but i'll assume that it's dead since i reflowed it real good and nothing changed. the chip is mec5105
          • kjchatman
            • Dec 2012
            • 209
            • united states
            is reprogramming easy enough? i know how to reprogram a bios
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              A shorted ec needs to be replaaced , not reballed. Its bit difficult to program these bga ec.
              • kjchatman
                • Dec 2012
                • 209
                • united states
                well i replaced the sio with a new one and the short on +rtc_cell is back. is measures 1.1 ohm resistance to ground
                • tom081081
                  • Jan 2023
                  • Poland
                  Hi kjatchman,
                  I have exactly the same issue - +RTC_CELL shorted to the ground (~1 Ohm) and no ALWON signal. I haven't done a short-circuit test yet because I don't have a thermal camera, I need to borrow.
                  Have you solved this problem on your laptop?
                  I would appreciate any advice
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Short on RTC is usually related to shortedRTC section of PCH . Trace this signal to PCH and check resistance there. If you are lucky,it can be a shorted cap on the backside of SOC but very unlikely.
                      DELL Latitude 7490 Notebook 7000 Specification for Upgrade or Repair
                      This specification for the DELL Latitude 7490 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7490 boardview and 7490 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7490...
                      09-06-2024, 12:36 PM
                      09-06-2024, 12:13 PM
