Lenovo G510 AMD Graphics Card not Detected
  • black_71
    • Oct 2021
    • 5
    • Morocco
    • Machine Model Number: Lenovo G510 (20238)
    • Specifications:
      • Motherboard Model Number: Factory (LA-9641P HannStar), Actual (LA-9641P Palwonn)
      • Motherboard BIOS Version: 79CN48WW(V3.07)
      • CPU: Factory (Intel i7-4702MQ), Actual (Intel i5-4310M)
      • GPU: AMD Radeon R7 M265
      • RAM: 2 x 4GB DDR3 1600Mhz (8GB)
      • Storage Device: Kingston A400 SSD + TOSHIBA MQ01ABD (in a 12.7mm Tray)
    • History, Symptoms and State of the Machine:
      • History: Some of the factory motherboard's components were fried, possibly due to overheating, but I'm not sure. The only difference between the factory and the actual motherboard is the vendor, which I purchased used from AliExpress. After replacing the motherboard, I couldn't get the laptop to boot; the screen was back, and the fan ran for approximately four seconds before shutting off, so I took it to a specialist, who fixed it by replacing the defective factory CPU with the actual one.
        The laptop functioned flawlessly until I installed a fresh copy of Windows 7 and discovered that the AMD Graphics Card had vanished from the Device Manager shortly after installing the drivers. I double-checked the BIOS settings and found that my Graphics Settings were set to Switchable Graphics not UMA. I upgraded the BIOS to v3.09 and then reverted it to v3.07 after seeing no changes.
      • Symptoms: After installing a fresh copy of Windows 7, the AMD Graphics Card vanished.
      • State of the Machine: The laptop is in fine working order, but getting the AMD Graphics Card to operate is critical because several of the softwares I use for my studies are dependent on it.
    What are my options for resolving this problem?
    Thank you!
  • mon2
    • Dec 2019
    • 14673
    Re: Lenovo G510 AMD Graphics Card not Detected
    Hi. Is it possible that the received board from AliExpress does not feature the AMD GPU on your logic board?
    Check around the logic board for the GPU. Most likely it will be covered with a heatsink but post pictures of any silk screen text on the board near this part. Do not remove the heat sink.
    The device driver follows the enumeration of the hardware. If the hardware is missing or disabled then there will be no need for the device driver nor will it be listed in the device manager tree.
    Also review this thread:
    https://forums.tomshardware.com/thre...8750m.2841347/
    • black_71
      • Oct 2021
      • 5
      • Morocco
      Hello there, mon2! Thank you so much for taking the time to read through my problem and offer a solution.
      Yes, I can certify that my logic board is equipped with an AMD Radeon R7 M265 Graphics Card (please see the images I attached)
      The issue is that the Graphics Card was previously visible and functioning OK, but it vanished after I messed around with the BIOS settings to get the laptop to read my UEFI USB drive containing the Windows 7 installation files.
      When I loaded a fresh copy of Windows 7 and discovered that the Graphics Card had vanished, I panicked and upgraded the BIOS to v3.09 from Lenovo's official support page, only to have it reverted to v3.07 after seeing no difference.
      • black_71
        • Oct 2021
        • 5
        • Morocco
        Anyone?
        • caspian
          • Oct 2015
          • 1591
          • Laptop
          Updating Bios is not enough. You are supposed to reporogram the Bios chip entirely using an external programmer. But first, take a backup of the Bios chip.
          • black_71
            • Oct 2021
            • 5
            • Morocco
            Thank you caspian for your response! I have an CH341A BIOS Programmer that comes with a SOIC8 Clip and Adapters.
            Where I can find a BIOS dump and how would I know that's going to work with my motherboard?
              Acer Aspire VN7-793G-73UU Notebook V Nitro Specification for Upgrade or Repair
              This specification for the Acer Aspire VN7-793G-73UU Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VN7-793G-73UU boardview and VN7-793G-73UU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              09-06-2024, 05:59 AM
              Acer Predator PH317-51-787X Notebook Helios 300 Specification for Upgrade or Repair
              This specification for the Acer Predator PH317-51-787X Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PH317-51-787X boardview and PH317-51-787X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              09-06-2024, 05:54 AM
              Acer Predator G3-572-74FZ Notebook Helios 300 Specification for Upgrade or Repair
              This specification for the Acer Predator G3-572-74FZ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the G3-572-74FZ boardview and G3-572-74FZ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              Acer Aspire A715-71G-56YF Notebook 7 Specification for Upgrade or Repair
              This specification for the Acer Aspire A715-71G-56YF Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A715-71G-56YF boardview and A715-71G-56YF schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              09-06-2024, 05:46 AM
              Acer Aspire A715-71G-75B3 Notebook 7 Specification for Upgrade or Repair
              This specification for the Acer Aspire A715-71G-75B3 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A715-71G-75B3 boardview and A715-71G-75B3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
