HP Pavilion 17-ab091ms - white charging light, but no power
  • tahc81
    • Nov 2019
    • 42
    • Slovakia
    #41
    Re: HP Pavilion 17-ab091ms - white charging light, but no power
    Originally posted by BMCappelletti
    I think I'm fine.
    Still need to check how to do all that.
    But if a broken BIOS cannot result in a short, so I don't see a point on trying to reflash it. Or did I get it wrong?
    I think the fried BIOS chip is like a Yeti = nobody ever seen him Generally speaking, BIOS issue usually stands for corrupted data preventing PC from starting. If you see BIOS shorted (pins 4 & 8), it's usually something else shorted, not the BIOS chip itself. 3V3 and 1V8 as well are connected to other components, and it can vary from single capacitor or diode to a mosfet or CPU/chipset. When 3V3 is not present and shorted, I usually using voltage injection and checking for the heat spot to identify the short.
    Note: if there's a short on 3V3, you will fail to read/write BIOS chip
    • BMCappelletti
      • Nov 2021
      • 152
      • Brasil
      #42
      That reminded me that the board is shorted-Where do you find it is shorted??
      https://www.badcaps.net/forum/showpo...19&postcount=3
      Maybe an issue with the 1V1 line, as both this caps should have 1V1 on it?
      • BMCappelletti
        • Nov 2021
        • 152
        • Brasil
        #43
        I will have a voltage injection tool tomorrow. So for now I was trying to find the issue with testing.
        But it does not seem too easy.
        • BMCappelletti
          • Nov 2021
          • 152
          • Brasil
          #44
          Just to add...
          I was watching some BIOS reflash videos and the guy mentioned that there should be 3V on pin 8.
          According to the board view I have it should, indeed. And ground on pin 4.
          I could find ground on pin 4 but on pin 8 I get only 0.08V.
          • BMCappelletti
            • Nov 2021
            • 152
            • Brasil
            #45
            Well... I got the voltage injector.
            Injected 1.2V on the pad from one of the caps I removed. The mobo is drawing 0.076 amps, which seems very low.
            I could not feel anything hot on the board.
            Should I up the voltage to 1.8V, which is the next step on the device?
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              #46
              Going by your thread from beginning, i still could'nt understand which "SHORT" you are talking about. can you please elaborate where do you find short??
              • BMCappelletti
                • Nov 2021
                • 152
                • Brasil
                #47
                Initialy, on these caps marked in red and green.
                On the board view I have they could be PC2012/PC2013/PC2014 and PC6009/PC6010.
                After cleaning this in the back of the board,
                the ones in red are not shorting to ground anymore. The ones in green were still and I removed them. The pads are still shorting to ground.
                And, after all these days tinkering with the board, I can find lots of caps shorting, including all those around the CPU area, in the back of the board.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  #48
                  I dont think its shorted. What is the exact resistance on those caps?? Remember, caps will show very low resistance near cpu/gpu area and even lower with onboard soc. Resistance above a couple of Ohms is not likely shorted.
                  • BMCappelletti
                    • Nov 2021
                    • 152
                    • Brasil
                    #49
                    Ok. Got it.
                    Those around CPU are like 1.8k ohms.
                    So, I'm back to squase zero. Almost. :p
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      #50
                      Btw, Did you checked LID Switch??
                      • BMCappelletti
                        • Nov 2021
                        • 152
                        • Brasil
                        #51
                        I mentioned it here (at least maybe it is this)
                        https://www.badcaps.net/forum/showpo...3&postcount=12
                        How should I exactly check it?
                        If you mean a specific LID switch board, this model does not seem to have it.
                        • BMCappelletti
                          • Nov 2021
                          • 152
                          • Brasil
                          #52
                          If I wanted to try turning it on without the daughter board, where the power button is, which pins on the daughter board connector I should short?
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            #53
                            Pin#16 to GND should turn it on. Red probe should be on GND and you need to touch pin16 with black probe.
                            • BMCappelletti
                              • Nov 2021
                              • 152
                              • Brasil
                              #54
                              Hmmm white light just went down and on again.
                              CPU not getting hot.
                              • BMCappelletti
                                • Nov 2021
                                • 152
                                • Brasil
                                #55
                                Please note that BIOS chip is 1.8V device, so you'd need 1.8V SPI adapter. And no, incorrect/broken BIOS image can't cause short on power rail. If the EC BIOS is a part of it, it could make some other issues, but at least 3.3V is completely independent of BIOS and EC.
                                Hi. I was re-reading the thread, to check if I missed something or had a clue on what to try next, and I think the BIOS on it is 3.3V, not 1.8V.
                                I even found it for sale stating 3.3V.
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  #56
                                  White light at dc jack blinks when you try to turn it on-Right?? That most probably indicates problem with AC-Adapter not properly recognised. Try with another HP Original adapter, if possible, check ADP_ID circuit thoroughly. I Think this model may require a 90W charger.
                                  • BMCappelletti
                                    • Nov 2021
                                    • 152
                                    • Brasil
                                    #57
                                    No, it does not blink. It's a solid white light.
                                    The original charger is a 120W one.
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      #58
                                      What you wrote here, indicates AD_ID problem. This is what i mean by blinking at dc jack. Solid white light when plugged in, try to trigger, light goes down and back.
                                      • BMCappelletti
                                        • Nov 2021
                                        • 152
                                        • Brasil
                                        #59
                                        Got it.
                                        I tried just once. Hope I shorted the right pins. But I can try to replicate it again.
                                        But, if it is what you say, what should I do next?
                                        • mcplslg123
                                          • Jun 2015
                                          • 7262
                                          • india
                                          #60
                                          First, confirm what i have described. If it's so then AD_ID needs to be checked.
                                            HP Pavilion Pavilion Desktop - 570-a079w Pavilion 570 J4205 Specification for Upgrade or Repair
                                            This specification for the HP Pavilion Pavilion Desktop - 570-a079w can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-a079w boardview and Pavilion Pavilion Desktop - 570-a079w schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                            09-12-2024, 03:44 PM
                                            HP Pavilion Pavilion Desktop - 570-p030na Pavilion 570 i3-7100 Specification for Upgrade or Repair
                                            This specification for the HP Pavilion Pavilion Desktop - 570-p030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p030na boardview and Pavilion Pavilion Desktop - 570-p030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                            HP Pavilion Wave Pavilion Wave Desktop - 600-a030na Pavilion Wave i3-6100T Specification for Upgrade or Repair
                                            This specification for the HP Pavilion Wave Pavilion Wave Desktop - 600-a030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave Pavilion Wave Desktop - 600-a030na boardview and Pavilion Wave Pavilion Wave Desktop - 600-a030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                            HP Pavilion Pavilion Desktop - 570-p056 Pavilion 570 i7-7700 Specification for Upgrade or Repair
                                            This specification for the HP Pavilion Pavilion Desktop - 570-p056 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p056 boardview and Pavilion Pavilion Desktop - 570-p056 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                            HP Pavilion Pavilion Wave Desktop - 600-a059na Pavilion i5-6400T Specification for Upgrade or Repair
                                            This specification for the HP Pavilion Pavilion Wave Desktop - 600-a059na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Wave Desktop - 600-a059na boardview and Pavilion Pavilion Wave Desktop - 600-a059na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
