L530 lenovo flashing without battery
  • Thermaltake
    Brain badcap
    • Aug 2015
    • 332
    • D12
    Hi, I have L530 and original battery not in best shape, but working, I tried two batteries and with both I got message that laptop wont charge battery cause it's not genuine. Laptop have ancient bios 1.06. And I would like to try and flash bios to see if there is any change, but I cant cause you need battery for it. Does someone know how to bypass bettery check for this laptop. I google a little but didn't manage to find anything useful. Thanks.
  • mon2
    • 14001
    Re: L530 lenovo flashing without battery
    The laptop does not work with only the adapter (no battery) ?
    The guru on laptop batteries and charging is on this forum.
    Contact Nicusor who developed the NLBA1 battery tool:
    https://www.direct-charging.com/blog...r-the-software
    Do update this thread for future readers.
      • 20656
      There is a mod for some old thnkpad models to remove the battery whitelist but this one isn`t covered.I don`t know if there`s any other mods out there that might work.
      https://github.com/hamishcoleman/thinkpad-ec
      Quote:
      Unfortunately, there are a small number of thinkpads with a model number from the "xx30" series that are using a completely different EC CPU and a different BIOS update strategy. Thus they are not currently able to be patched. This is known to be the case for at least the L430, L530 and E330.
      • Thermaltake
        Brain badcap
        • Aug 2015
        • 332
        • D12
        Laptop work just fine with and without battery. It just wont charge saying at the boot start that battery is not original bla bla and to continue press esc. And in windows also pops the message saying not geniune battery that I need to replace it. And like I said this is second battery and I know this one is working and was normally charging on last L530 that I had.
        P.S
        I remember my friend have T430 they have same batteries I'll try to borrow the battery from him and flash to see if something change.
          • 20656
          The battery is whitelisted in the EC .Nicusor is only here to promote his product ,not here to share any bios dumps,schematics or any other knowledge
            • 20656
            Originally posted by Thermaltake
            P.S
            It might work,might not https://forum.thinkpads.com/viewtopic.php?t=110281
            • Thermaltake
              Brain badcap
              • Aug 2015
              • 332
              • D12
              It worked, his battery from T430 which is extended one ss working, and laptop is not reporting that it's not geniue and charging battery normally.
              I flash bios from initial 1.06 to 2.76 now, and clear CMOS, and configure bios. But still this original battery when I insert it said that it's not geniune and won't charge it, I don't understand.
              Found problem.
              I google FRU from battery she fits in but, it's for L410, L412, L420, L421, L510, L512, L520, T410, T410i, T420, T510, T510i, T520, W510, W520, and not for L530. Someone that had this laptop before put original battery in but with FRU that is not compatible with this L530 laptop.
              This L530 needs FRU 45N1001 battery which looks the same as this up model FRU 42T4791, but this 45N1001 is only for L430 L530 T430 T530 W530 imagine that, f.... lenovo.
              • leecher
                • Dec 2021
                • Austria
                You can patch EC online (without need to flash) to enable non-genuine battery or battery from older NB series: https://github.com/leecher1337/thinkpad-Lx30-ec
                • HTR-Informatique
                  Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                  by HTR-Informatique
                  YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                  I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                  On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                  I also changed the screen because the PC fell and the screen was broken.
                  I changed the battery with a new and original battery.
                  I also had corrosion/oxidation on the...
                  02-09-2025, 06:51 AM
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • code share
                  Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                  by code share
                  I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                  Here's what I've tried so far:
                  • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                  • Booted successfully on AC power only with the battery disconnected
                  • Visual inspection of the battery — no swelling, burn marks, or connector damage
                  • Battery
                  04-21-2025, 12:50 PM
                • mrkmpn
                  Lenovo Yoga C930-13IKB EYG70 NM-B741 Battery not detected.
                  by mrkmpn
                  Hello, I have a customer that brought this laptop in after replacing his battery. He said his original battery charge was not lasting long, and after replacing the battery with one purchased from iFixit, the charging worked for about 30 minutes and then stopped, and the battery is no longer detected by windows.
                  This laptop powers on when the AC adapter is connected, and my USB-C multimeter shows current being used with both ports, but the charging light does not come on, and in Windows the battery icon shows an X as if there is no battery present. If I disconnect the AC adapter,...
                  03-13-2024, 01:54 PM
                • pabloroggeri
                  Lenovo V310-15ISK - It doesn't work after changing the battery
                  by pabloroggeri
                  Good guys. I changed the battery to a Lenovo V310-15ISK.
                  The laptop worked perfectly, I changed the L15C4A02 battery because it didn't last very long.
                  When I connected the new battery, the charging LED stopped lighting up and the one next to the charging pin also did not react when I pressed the power button. Minutes before changing the battery it worked perfectly and stopped working after putting the new one in. Even if you put the oroginal battery in or connect it without the battery, no LED lights up when you press the power button nor does it give an image, nor does the...
                  08-23-2024, 12:01 PM
