Mbp 15 mid 2010 (no ppbus boost no batt)
  • reassor
    • Apr 2021
    • 176
    • Poland
    Hey all.
    Bought this pile of junk as a project :P
    So mobo is 820-2850-a (i5)
    Symptomps :
    -no battery detected (It sees it but does not know cycles or anything for that matter - brand, model etc.)
    - no PPBUS_G3H boost to 12.6v - it stays 12.24v whole time. Yet SMC works. With or w/o bat / BIL etc.
    Everything else works as far as i can tell
    Any ideas before i dump money again for random junk to do SMC swapy?
    forgot to add - all current sensing tested + u7000 swaped (was dead)
  • dellxps15
    • Feb 2014
    • 1591
    • italy
    Re: Mbp 15 mid 2010 (no ppbus boost no batt)
    report u7000 voltage.
    green light on magsafe ?
    • piernov
      • Jan 2016
      • 4437
      • France
      https://www.badcaps.net/forum/showpo...50&postcount=2
      2.2.2. Battery not detected
      Issue on charging circuit SMBUS.
      Check voltage and diode mode to ground on charging circuit SMBUS SDA and SCL lines
      • reassor
        • Apr 2021
        • 176
        • Poland
        yes green light. Voltages are comparable to what you listed in some old thread.
        will list em if needed. Will get inside again tomorrow cause ordered airport card with mount and stuff so ill check them again.Thx for reply
        Thx Piernov for that link.
        • reassor
          • Apr 2021
          • 176
          • Poland
          Diode mode (red on ground). Battery out. BIL disconnected (with it plugged in same result)
          SDA = 0.532v
          SCL = 0.516v
          voltages: AC + batt
          SDA = 3.41v
          SCL = 3.41v
          voltages: Batt only
          SDA = 3.41v
          SCL = 0.81v
          Detect_L is pulled down to 0.222v
          I hope i didn't swap the labeling of those lines
          PPBUS_G3H = 12.24v on charger+batt (w/o batt same) and 11.58v on battery.
          Camera cable is destroyed so cannot say if light sensor is working. All functions like brightness, KB lights and fans seem fine.
          Cheers
          • reassor
            • Apr 2021
            • 176
            • Poland
            All measured on charger only with power off state.
            Near or on chip itself
            U7000 / ISL6259HRTZ
            Pin01 = 0v CHGR_AGATE
            Pin02 = 18.54v PPCHGR_DCIN
            Pin03 = 4.46v CHGR_ACIN
            Pin04 = 3.40v VRFQ
            Pin05 = 1.16v CHGR_ICOMP
            Pin06 = 3.41v CHGR_CELL
            Pin07 = 0.86v CHGR_VCOMP
            Pin08 = 2.046v CHGR_VNEG
            Pin09 = 0.03v CHGR_AMON
            Pin10 = 3.416v SMBUS_SMC_5_G3_SDA
            Pin11 = 3.416v SMBUS_SMC_5_G3_SCL
            Pin12 = 3.416v PP3V42_G3H
            Pin13 = 3.416v CHGR_RST_L
            Pin14 = 3.277v SMC_BC_ACOK
            Pin15 = 0.062v CHGR_BMON
            Pin16 = 12.24v CHGR_BGATE
            Pin17 = 12.27v CHGR_CSO_N
            Pin18 = 12.27v CHGR_CSO_P
            Pin19 = 5.031v PP5V1_CHGR_VDD
            Pin20 = 5.012V PP5V1_CHGR_VDDP
            Pin21 = 0.219v CHGR_LGATE
            Pin22 = GND 0v
            Pin23 = 12.27v CHGR_PHASE
            Pin24 = 12.46v CHGR_UGATE
            Pin25 = 16.52v CHGR_BOOT
            Pin26 = 18.16v CHGR_SGATE
            Pin27 = 18.42v CHGR_CSI_N
            Pin28 = 18.42v CHGR_CSI_P
            • reassor
              • Apr 2021
              • 176
              • Poland
              Just reporting in.
              As suspected it was SMC. Got 1 for 30$ and now everything works like a charm
              thx all for patience and my mumbling ;p
              • dellxps15
                • Feb 2014
                • 1591
                • italy
                glad to ear it i think all in this thread was with no idea left as all remind of bad smc, but u write on top that smc was ok
                • reassor
                  • Apr 2021
                  • 176
                  • Poland
                  well no ppbus adjust to 12.56v was kinda give away its borked. But i was hoping there was something with comunication :P - For me it was working since everything else smc wise was working
                  Found 1 online store here in poland with "refurbished" chips - so i thought oh cool it will come reballed ready to go
                  If you saw what i got you would
                  It was a cutout from dead board - like if you took a electric saw and cut the fragment with smc on it LOL.
                  Had to reball it by hand (do not have stencil for it) and it fixed everything - there was a moment of horror when i plugged magsafe in
                  Btw After we soldered it on i measured with diode setting (red to ground):
                  SDA = 0.505v
                  SCL = 0.506v
                  So huge diffirence.
                  I think i fried it when i was measuring u7000 (was hunting for good 1 from our old boards - 4 didnt work LOL)
                  Bough new ones and that did the trick (these are cheap).
                  Cheers - i learned alot about macs (my first 1 ;p).
                  Think ill keep it
                  • piernov
                    • Jan 2016
                    • 4437
                    • France
                    Why not buy a full donor board?
                    • reassor
                      • Apr 2021
                      • 176
                      • Poland
                      These cost as much as i paid for that laptop (even broken ones) atleast here in poland.
                      • piernov
                        • Jan 2016
                        • 4437
                        • France
                        Buy from Aliexpress, less than 20€.
                          HP EliteBook 840 G5 + Samsonite Base Boost Notebook 800 Specification for Upgrade or Repair
                          This specification for the HP EliteBook 840 G5 + Samsonite Base Boost Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G5 + Samsonite Base Boost boardview and 840 G5 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                          09-06-2024, 09:00 AM
                          HP EliteBook 830 G5 + Samsonite Base Boost Notebook 800 Specification for Upgrade or Repair
                          This specification for the HP EliteBook 830 G5 + Samsonite Base Boost Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G5 + Samsonite Base Boost boardview and 830 G5 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                          HP ProBook x360 440 G1 + Samsonite Base Boost Hybrid (2-in-1) Specification for Upgrade or Repair
                          This specification for the HP ProBook x360 440 G1 + Samsonite Base Boost Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 440 G1 + Samsonite Base Boost boardview and 440 G1 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                          HP ProBook 640 G4 + Samsonite Base Boost Notebook 600 Specification for Upgrade or Repair
                          This specification for the HP ProBook 640 G4 + Samsonite Base Boost Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G4 + Samsonite Base Boost boardview and 640 G4 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
