HP Elitebook Folio 9480m Fake charge after adapter unplugged
  • classicandy
    • Apr 2018
    • 309
    • Nigeria
    Hi everyone
    I have this HP Elitebook Folio 9480m that continues charging even after the Adapter has been unplugged.
    No sign of spill or corrosion on the motherboard. I have replaced Charging IC [BQ736] and no luck.
    No schematic available but the charging section and some other components seems to be similar to that of Folio 9470m and Elitebook 840 g1.
    Please I need assistance on this. Thanks
  • mon2
    • 14663
    Re: HP Elitebook Folio 9480m Fake charge after adapter unplugged
    Hi.
    1) post the full markings of the first 2 mosfets connected to this charger ic.
    Then check the resistance of each mosfet to see if they are shorted. Power down and remove the battery. Then meter in resistance mode.
    2) see the resistance chart at this URL:
    http://electronicsbeliever.com/how-t...-is-defective/
    3) next, with battery & ac adapter attached, what is the voltage of ACDET?
    Remove the AC adapter, what is the voltage on ACDET?
    • classicandy
      • Apr 2018
      • 309
      • Nigeria
      Originally posted by mon2
      Hi.
      Thanks for quick response.....
      Page not found in the link you sent. Seems broken
      • mon2
        • 14663
        • classicandy
          • Apr 2018
          • 309
          • Nigeria
          Thanks for this info, it is very helpful. I haven't been using Resistance Check to test MOSFETs before. It is usually Physical inspection or Continuity test.
          However, i was able to detect the MOSFET [Q6011] that seemed to be the problem BUT after removing the MOSFET, I decided to read it out of the board. It is reading normally meaning it is not defective. The empty space for the Q6011 MOSFET is still reading that it is defective.
          • mon2
            • 14663
            1) Post the readings on Q6011 PCB pads.
            Resistance between SOURCE & GATE ?
            Resistance between SOURCE & DRAIN ?
            Resistance between GATE & DRAIN ?
            2) Then do the same for mosfet Q6012.
            3) Power up -> meter in DC voltage setting -> what is the voltage with adapter connected @ ADP_DET ?
            Remove the adapter -> what is the voltage with battery @ ADP_DET ?
            • classicandy
              • Apr 2018
              • 309
              • Nigeria
              Thanks so much. You are a lifesaver. I have been able to fix it
              • classicandy
                • Apr 2018
                • 309
                • Nigeria
                It turns out it was Q6012 MOSFET that was faulty. The internal diode in Q6012 MOSFET was defective. I have replaced both Q6011 and Q6012 MOSFET and the motherboard is working properly now.
                Thanks again
                • Mark3000
                  • Nov 2014
                  Thanks again
                  Hello
                  I have the same problem with the power supply, what did you replace Q6011 with? It is marked "E4 VUD" I found no data about it....
                    • 21874
                    Originally posted by Mark3000
                    Hello
                    PEA28BA https://www.badcaps.net/forum/showpo...65&postcount=4
                    (@mon2 ,the LG fridge is mine )
                    • mon2
                      • 14663
                      Texas instruments charger chips like to use N-channel mosfets.
                      The parts are very common and have the usual 1-2-3 for source; pin 4 as gate; 5-6-7-8 for the drain.
                      Locate any donor board and the first 2 DCin mosfets will most likely be N-channel version. Confirm it and replace to test.
                      • mon2
                        • 14663
                        Lol 😆
                        • Mark3000
                          • Nov 2014
                          Thanks a lot
                            HP EliteBook Folio EliteBook Folio G1 Notebook Specification for Upgrade or Repair
                            This specification for the HP EliteBook Folio EliteBook Folio G1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook Folio G1 boardview and EliteBook Folio G1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                            09-06-2024, 06:34 AM
                            HP EliteBook Folio EliteBook Folio G1 + USB-C Universal Dock Notebook Specification for Upgrade or Repair
                            This specification for the HP EliteBook Folio EliteBook Folio G1 + USB-C Universal Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook Folio G1 + USB-C Universal Dock boardview and EliteBook Folio G1 + USB-C Universal Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                            09-06-2024, 06:30 AM
                            09-06-2024, 05:30 AM
                            HP EliteBook Folio EliteBook Folio G1 Notebook PC (ENERGY STAR) Notebook Specification for Upgrade or Repair
                            This specification for the HP EliteBook Folio EliteBook Folio G1 Notebook PC (ENERGY STAR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook Folio G1 Notebook PC (ENERGY STAR) boardview and EliteBook Folio G1 Notebook PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
