hm70 chipset 30min timer
  • bigbily09
    • Dec 2014
    • 68
    • qc
    is there anyway to remove or bypass the 30min timer of an hm70 chipset after upgrading cpu to core i series.
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: hm70 chipset 30min timer
    I had no idea what you were talking about and thought you were making this up but a quick internet search sent me down a two hour rabbit hole on this topic.
    That's absolutely crazy. It works perfectly but arbitrarily decides to shut down the computer after 30 minutes because you didn't buy a system with a better chipset to begin with.
    All that said, I have no actual solution to your problem, sorry.
    • mon2
      • 14662
      Learning something new every day Crazy.
      Found this:
      https://www.tonymacx86.com/threads/a...utdown.225447/
      • age80
        • Jun 2013
        • 55
        • Greece
        Clean Me Region issue for sure...
          • 21862
          That will not work, for sure...
          • age80
            • Jun 2013
            • 55
            • Greece
            You are right...
            HM70 supports only intel pentium dual core until B980 and intel pentium like 1000M
            You'll need HM76 or HM77 for an iCore
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              You are right...
              Is the chipset a direct replacement? They could desolder the old one with a BGA rework station and put the better one?
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                bigbily09 received an answer this morning, and I don't know why he create another topic in different forum section (probably expecting a miracle to happen this way) about the same thing.
                https://www.badcaps.net/forum/showpo...62&postcount=2
                Become a Badcaps supporter
                Thanks to all supporters.​
                • Djosla
                  • Dec 2012
                  • 246
                  • Montenegro
                  Yes you can, I have done it several times.Depending on your model you might need firmware reprograming on a motherboard.
                  • bigbily09
                    • Dec 2014
                    • 68
                    • qc
                    Ok thanks so now i know that cleaning me region is not a possible solution because the timer that was programmed is in the chipset not in the bios so cleaning me is not a solution btw thanks for all your reply but if you have other suggestion im always open to learn new things thanks
                    • pongis
                      • Aug 2017
                      • 6
                      • siauliai
                      i have solution. me not help to clean so need mod me region.
                      inject this me region
                      • audifann
                        • Dec 2023
                        • PL
                        Hello.
                        It's been a while, but I'll share my experiences here on this topic.
                        In my case (for my laptop) Your dump not worked.
                        I have laptop ASUS X401A-WX095V (intel HM70 chipset) - originally came with Celeron B820. I swapped CPU to i5-2410M (from Toshiba Satellite Pro C660 on HM65 chipset) and like other Users every 30 min laptop suddenly turned off. But...
                        Yesterday I found a solution which is as follows:
                        1. Dumped BIOS from EEPROM using external programmer (I using latest BIOS for this laptop ver 212),
                        2. Next used Hex editor for downgrade ME Region to 7.0.4.1197. I used stock/clean ME Region 7.0.4.1197 for this downgrade purpose,
                        3. I flashed back new modded BIOS with new ME Region,
                        ..and after that, laptop was able to turned on, enter to BIOS, but couldn't boot from any connected media drive (ssd, usb)..., so I applied Linux version of "corna / me_cleaner " from github.
                        So last step was:
                        4. I runed "me_cleaner.py -S" script on my new modded BIOS with downgraded ME Region 7.0.4. In my case works first suggested option with capital S from me_cleaner instruction.
                        Thats it!!
                        After that my laptop is able to boot from any media drive and working without 30 min shutdown
                        note:
                        -my Asus X401A on HM70 had original BIOS with ME Region 8.0.10.1464
                        -donor Toshiba C660 on HM65 had BIOS with ME Region 7.0.4.1197
                        Maybe this will help those who are still looking for a solution. Hope it does
                        Best regards from Poland!
                        • audifann
                          audifann commented
                          Editing a comment
                          P.S. After running the script in 4th step, You need to again flashed back bios with the second modded bios file.
                      • Amin89
                        Bypass timer apc bx650ci
                        by Amin89
                        How to disable the timer on the APC BX650CI-MS UPS, because it shuts down every 15 minutes even though the battery is still full....
                        10-18-2025, 09:01 AM
                      • DynaxSC
                        Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                        by DynaxSC
                        Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                        For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                        06-10-2023, 11:30 AM
                      • DeanWy
                        WD Sentinel DS5100 (NAS) boot issues
                        by DeanWy
                        I have a Western Digital Sentinel DS5100 NAS system which has stopped working. It has dual BIOS. I bought the system second hand with an already broken primary BIOS (it rebooted multiple times until second BIOS was used).
                        It worked until recently. The system was idle in Windows Server 2012 and a BSOD occurred, I think it was 'critical process died'. Thereafter it didn't boot, it just sat there with no video output and fan speed at 100% (there's a proprietary Windows driver by WD which controls the fan, outside of that it always runs at 100%).
                        There...
                        07-30-2024, 04:13 AM
                      • Spudgun
                        Why doesn't current just bypass faulty capacitors.
                        by Spudgun
                        Hello esteemed members. I appreciate that my question will strike some as being somewhat childishly simple, but it genuine perplexes me! I have repaired several laptops before by removing a faulty capacitor that was short-circuiting the motherboard, whereupon the laptop would then work. For me, it begs the question that, if the current can bypass where the capcitor was when it has been removed, why didn't it just bypass it when it was present and faulty,? I can't get my head round the premise that if the other side of the capacitor is connected to ground, then why doesn't the current simply bypass...
                        04-01-2025, 10:33 AM
                      • qayyum786
                        *Use Full MOST COMMON I.C FOR LAPTOP YOU SHOULD HAVE IN STOCK*
                        by qayyum786
                        *MOST COMMON I.C FOR LAPTOP*
                        *YOU SHOULD HAVE IN STOCK*
                        *Charging IC
                        8682L OZ8682L OZ8682LN QFN-16 Chipset
                        OZ8681LN OZ8681L OZ8681 8681 8681L QFN-16 Chipset
                        ISL88731CHRTZ ISL88731C 88731C QFN-28 Chipset
                        ISL88731HRZ ISL88731QFN-28 Chipset
                        ISL6251AHAZ ISL6251A ISL6251 SOP-24
                        ISL95521HRZ ISL95521 95521HRZ QFN-32 Chipset
                        AXP288 QFN-76
                        AXP288C QFN-76
                        CD3301 CD3301RHHR QFN-36 Chipset
                        CD3301BRHHR CD3301B QFN-36
                        BQ24705
                        BQ24707 BQ707
                        BQ07A BQ24707A QFN-20
                        BQ715 BQ24715 BQ24715RGRR
                        05-26-2020, 06:13 AM
