Hp Spectre x360 DAY0DMB2AA0 black screen
  • reset1986
    • Dec 2014
    • 308
    • italia
    hi, I have this hp that had a PU18 ic that overheated and did not turn on, this managed the ram, replaced the pu18 ic and now the pc turns on, the fan runs but I have a black screen, measured the voltages I miss + VIN_VCCGT on PL21, this is managed by pu12 and pq13
    pu12
    pin 1 4.7v
    pin 2 2V
    pin 3 4.7V
    pin 4 4.8
    pin 5/6/7/8 0V
    who can help me? Thank you
  • Sephir0th
    • Oct 2020
    • 1289
    Re: Hp Spectre x360 DAY0DMB2AA0 black screen
    It's No issue when you can't measure VCCGT with your Multimeter. It's Normal to Not be present without load.
    Checked all coils for Short or asking other way around, all other voltages are Coming Up?
    Tested With known working HP charger of correct wattage and known working RAM?
    FairRepair on YouTube
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3627
      • slovakia
      "PU18 ic that overheated and did not turn on, this managed the ram"
      bad news for ram chips
      • reset1986
        • Dec 2014
        • 308
        • italia
        thanks on the other hand, no short coils, I have the right voltages, only vccgt is missing
        The RAM are welded, after the seat of the pu18 now I have 1.30v, with the faulty ic the car did not turn on
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3627
          • slovakia
          rams are very fragile to bad voltage
          • reset1986
            • Dec 2014
            • 308
            • italia
            i did a reflow on the rams, still black screen, the rams seem to work,
            vcc ram 1.30v 78ohm,
            vccgt 0v 4ohm
            vcore 0.90v. 4ohm
            it may be that there is no communication between ram and cpu?
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3627
              • slovakia
              when ram chips goes bad by bad voltage reflow/reball dont help
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                VCCGT -you cant measure with multimeter. Still you can put your probe on this coil while powering on and there might be a slight deflection on your multimeter. that will prove there is nothing wrong in VCCGT . This signal comes at the last stage of power sequence and at the time of posting. I'll strongly suggest to flash bios first.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  vccgt 0v 4ohm
                  vcore 0.90v. 4ohm
                  To check communication between cpu and ram, you can check SMBUS DATA/CLOCK on ram slot. If present, communication is very likely ok. You need DSO to be 100% sure but presence of voltage on those pins is almost a sure sign of communication ok between ram and cpu.
                  • reset1986
                    • Dec 2014
                    • 308
                    • italia
                    ok, I had tried to flash the bios, I extracted the 8 mb platform 0804F file on the hp site, still black screen, I will try the ram signals you suggested if there are voltages
                    • reset1986
                      • Dec 2014
                      • 308
                      • italia
                      i measured some ram points, there seems to be communication with cpu, 0.6v,
                      i did a reflow on the cpu but still black screen, other ideas on what it could be?
                      • Sephir0th
                        • Oct 2020
                        • 1289
                        Why did you do that?! You have risked an irreparable damage to the CPU, If it isn't already dead...
                        Till this Point it was possible it is Just a Bad RAM Chip. Now it could be a "no fix" at all...
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          You reflowed the cpu with hot air gun or Bga machine?? If it is hot air gun being used, there is high chance of cpu itself getting damaged. However, with bga machine reflow with correct profile, cpu will not be damaged.
                          • reset1986
                            • Dec 2014
                            • 308
                            • italia
                            I have been reballing for years, I use a ht r490, correct profile, 225 degree recast, the cpu still works but I have not solved the black screen problem
                            if i desalt one ram chip at a time can it work with only one chip?
                            the ram ic on the motherboard are 2
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              Hmm. Not sure it will work or not after desoldering one of those 2 ram chips. Never done that before.
                                HP Spectre x360 Spectre x360 - 15-df0068nr Hybrid (2-in-1) 15 Specification for Upgrade or Repair
                                This specification for the HP Spectre x360 Spectre x360 - 15-df0068nr Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spectre x360 - 15-df0068nr boardview and Spectre x360 - 15-df0068nr schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                09-06-2024, 07:20 AM
                                HP Spectre x360 Spectre x360 - 15-ch050na Hybrid (2-in-1) 15 Specification for Upgrade or Repair
                                This specification for the HP Spectre x360 Spectre x360 - 15-ch050na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spectre x360 - 15-ch050na boardview and Spectre x360 - 15-ch050na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                09-06-2024, 06:21 AM
                                HP EliteBook x360 1030 G4 + Spectre Tech Tote Hybrid (2-in-1) Specification for Upgrade or Repair
                                This specification for the HP EliteBook x360 1030 G4 + Spectre Tech Tote Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G4 + Spectre Tech Tote boardview and 1030 G4 + Spectre Tech Tote schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                09-06-2024, 11:39 AM
