Hello everyone, the pc in question does not recognize any type of original dell battery charger. Consequently it does not charge the battery. Can you help me? Thank you
Dell 5580, ac adapter not recognized.
Re: Dell 5580, ac adapter not recognized.
Resistance to ground, and voltage at PL3 is...?----------------------------------------------------------------------------------------------------------------------------------------------------------
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae.. -
Voltage and resistance to ground on PL4 is OK, but is not important for your problem. So you must find PL3 and measure values if you want the problem to be solved. Don't be lazy - disassemble the machine, remove the board and find the PL3.----------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
thank you so muchComment
by mcplslg123MODEL:
ELL 7506 2-IN-1
M/B: HELLCAT 14 MS TGL 8L (19860-1)
PROBLEM: NO AC ADAPTER
The unit works fine with adapter but gives this message. The adapter is genuine dell 65W(tested ok). PS_ID is working correctly and reaches SIO.R4305 is correct at 33.3 ohms.
PU4301 gate is correct at 3.3V as well as PU4415 gate voltage at 1.8V is correct. 19V reaches PR4401(CLR).
Charging IC is ISL9538C
01 Resistance between CSIP/CSIN is about 2.2 ohms(PR4422/4423 is of correct value)
02.Resistance between CSOP/CSON is also correct at 2.4 ohms (PR4424-25 is... -
This specification for the DELL Inspiron 5580 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5580 boardview and 5580 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 5580...09-06-2024, 08:20 AM
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... - Loading...
