iPad Pro 10.5 - Where to find coils
  • struggleIT
    • Jan 2021
    I've got an iPad Pro 10.5 (A1709) that will not charge. It pulls .01 amps. I went through the motherboard and found a few loose/missing coils (or what I'm assuming are coils). I have attached pictures of the coils and I'm wondering if anyone knows the exact parts I need and where I can get my hands on them without having to but a whole doner board? Appreciate any help. https://imgur.com/gallery/eWJGloq
  • mon2
    • 14660
    Re: iPad Pro 10.5 - Where to find coils
    Yes, those are inductors (aka coils).
    1) be sure to confirm the diode readings as well for your logic board.
    https://logi.wiki/index.php/iPad_Dio...#iPad_Pro_10.5
    2) sometimes the issue can be related to the flex charging cable. Failure of the local tristar chip is very common. Assorted youtube videos on such coil repair and replacement.
    3) you can try:
    MobileSentrix ; they have a usa and Canada branch
    Union Repair ; China
    Vip programmer ; China
    US $4.98 | 10pcs/lot For ipad 2/3/4/5/6 air air2 mini 1-4 Backlight Diode Coil D4001 L4001 V3 L8225 2R2 / 4R7 D8228 L2200
    https://a.aliexpress.com/_mNdLNrn
    Be sure to indicate which coil with your pix.
    Check the 2R2 inductors from Bourns at Arrow electronics. Share the dimensions of each first.
    Check solder joints for each.
    • mon2
      • 14660
      and
      https://www.vipprogrammer.com/ipad-3...rs6u597eltm1l4
      The large 2R2 SMD inductor appears to be suitable for your repair.
      However, do measure the size of the part and then we can check if it is available through local distribution (ie. Arrow has a great inventory of such parts).
      • GeirAndersen
        iPad .pcb file collection
        by GeirAndersen
        I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
        Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
        IPAD COLLECTION 1
        +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
        +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
        +---iPad mini3 820-00008(A1599) 820-00002(A1600)
        +---iPad mini4 820-00180(A1538) 820-00177(A1550)
        +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
        +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
        12-09-2024, 09:28 AM
      • Victor Moreira Silva
        Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
        by Victor Moreira Silva
        I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
        Well, my decice specs are the following:
        Model: Acer Nitro 5 AN517-54-55T5
        CPU: Intel Core i5-11400H
        GPU: NVIDIA GeForce GTX 1650
        Motherboard: GH51G LA-L181P Rev:1c
        The symptom:
        When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
        05-26-2025, 10:49 AM
        by Vesko356
        08-11-2023, 03:27 AM
      • DJbapt59
        Asus Vivobook x421a
        by DJbapt59
        I recently picked up a laptop that was about to be thrown away to try to repair it. I've tested quite a few things, but I don't know where to look anymore. Could you please help me?
        Brand: Asus Vivobook
        Motherboard reference: x421da, Rev 2
        Context:
        The person who gave it to me mentioned it might have been exposed to water, but they weren't sure. After opening it up, I couldn't find any signs of water damage or oxidation on the motherboard.
        The first thing I did was to connect the PC to a power supply: 19V stable and...
        01-24-2025, 05:34 PM
      • grimacelord
        Apple iPad Pro 3rd Generation 12.9" (A1876) No Power/Charge When Screen Is Connected
        by grimacelord
        Hello.
        Working on an Apple iPad Pro 3rd Generation 12.9" that has a weird issue. When the display is NOT connected, the iPad will charge and power on normally. I know it's on because I can hear notification sounds and the charging notification sound.
        If I connect a brand new display to the logic board, the iPad will not turn on at all. When I connect the iPad to an 18W wall charger and a USB-C ammeter, I can see that the iPad is attempting to charge, but constantly "resets" after just a moment or two.
        For example, when I connect the iPad to...
        04-15-2022, 11:06 AM
