Please help ! Lenovo dg421 dg521 dg721 nm-b242 rev 1.0
  • gecce1978
    • Mar 2018
    • 38
    • türkiye
    Hi guys, The problem of lenovo laptop is faint screen(backlight) lenovo logo font looks too dark..
    my question is : I have attached the pictures of the motherboard,Which areas do I need to check..which component is controlling the backlight...
    Note:screen and cable absolutely solid...
  • mon2
    • Dec 2019
    • 14256
    Re: Please help ! Lenovo dg421 dg521 dg721 nm-b242 rev 1.0
    see attached and check the +20V feeds for the LCD backlight - believe these will be of interest:
    a) PQ1007 which you can read @ PJ1002. Use your meter in volts mode, with red lead on PJ1002. Black lead on a good ground on the logic board. Post your reading.
    b) PU902 appears to be the boost regulator that takes in +5volts and boosts it to +20V for the backlight LEDs.
    Pins 1 & 2 on the LCD connector = LEDVDD. Tracing LEDVDD rail you can see it is connected to +20V.
    Confirm the voltage of LEDVDD rail. If this rail is not +20V then this could be the issue that is causing the backlight to not behave normally.
    Start with the above..
    c) just added the boardviews of the board
    UMA version
    DIS version
    • gecce1978
      • Mar 2018
      • 38
      • türkiye
      thank you so much 🙏
      Sir,How can I test it with a multimeter?
      • gecce1978
        • Mar 2018
        • 38
        • türkiye
        Check Pq1005 mosfet ?
        • mon2
          • Dec 2019
          • 14256
          Carefully check the voltage on pin 1 of the lcd connector and post the voltage your meter reports.
          Use DC volts setting, red lead on pin #1, black on ground.
          Best to do this with the screen attached but as noted, be very careful to not slip on the pins.
          • Sametbey
            • Jan 2021
            • 229
            • Turkey
            You should see + 20V on 1 and 2 pins of the Panel socket on the motherboard, + 3.3V on pin 14 and pin 16.
            I'm not happy to be so strong. because it's not humanly
            • gecce1978
              • Mar 2018
              • 38
              • türkiye
              Monday I will look and information,thank you very much for helping me.. 🙏
              • gecce1978
                • Mar 2018
                • 38
                • türkiye
                No 3.3v on 14th and 16th legs
                • gecce1978
                  • Mar 2018
                  • 38
                  • türkiye
                  1st and 2nd legs come in 20 v
                  • mon2
                    • Dec 2019
                    • 14256
                    What is the exact voltage on lcd connector, pin 14?
                    This is an active low signal. If logic low then display will remain OFF.
                    • gecce1978
                      • Mar 2018
                      • 38
                      • türkiye
                      no signal
                      • gecce1978
                        • Mar 2018
                        • 38
                        • türkiye
                        lenovo text looks faint
                        • Sametbey
                          • Jan 2021
                          • 229
                          • Turkey
                          LVDS 14pin controlling 119pin of BL_ON IO chip. 16pin INV_BL is controlling processor via R19. R18 must be + 3.3V on one leg and 2.6V on the other. R19 can be removed. does not control luminosity.
                          • gecce1978
                            • Mar 2018
                            • 38
                            • türkiye
                            Samet bey,what is r19 ?
                            • Sametbey
                              • Jan 2021
                              • 229
                              • Turkey
                              Check out the boardview file. It coincides with the back of the LVDS socket.
                              • stsoukis92
                                • Oct 2021
                                • 4
                                • Greece
                                Hello!I have the same motheboard!When i plug the charger, the laptop is taking around 0.23A for few seconds and next 0.0!I have already checked with multimeter,i have 20v on the input and to the capacitors aroung the power supplies.I have also checked the voltage around the sio chip and nowhere exist 3.3v!
                                  Lenovo IdeaPad 320-15IKB DG421 DG521 DG721 Laptop Schematic
                                  NM-B242 NM-B241 Rev 1.0...
                                  10-08-2024, 01:49 AM
                                  Lenovo 3000 Series Schematic
                                  Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                  3000 C100 laptop with Braille keyboard
                                  Lenovo 3000 C
                                  C100, C200 - 15-inch XGA screen
                                  Lenovo 3000 N
                                  N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                  N500 - 15.4 inch screen.
                                  Lenovo 3000 V
                                  V100, V200 - 12.1-inch WXGA models
                                  Lenovo 3000 G
                                  G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                  10-04-2024, 06:05 AM
                                  Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                                  This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                                  09-06-2024, 06:40 AM
                                  This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                                  09-06-2024, 06:06 AM
                                • derradji89
                                  Need help Lenovo MIX 320-10lCR domaine name SERCOL
                                  by derradji89
                                  Hi everyone 🤗
                                  I have a Lenovo MIX 320-10lCR computer.**
                                  1. **Operating System**: Windows 10 ** Education** 64-bit.
                                  2. **User Account Restrictions**: The account I'm using has heavily restricted permissions via **UAC** and **Group Policy**. This means I cannot install any software without admin rights, adjust system time, run Command Prompt as administrator, or modify the registry via Regedit—all are blocked.
                                  3. **BIOS Password Protection**: The BIOS is locked with a password, preventing me from installing a new operating system.
                                  4. **BIOS Chip Reflashing**: Currently,...
                                  04-19-2025, 03:04 PM
