help with samsung rv415 ba41-01649a
  • marcelofct
    • May 2019
    • 122
    • chile
    Hi ! , I hope you are well I need help with the following motherboard ba41-01649a is a samsung rv415 I attach the schematic, the problem is that no usb port works, check voltages, enable, the IC TPS2062ADRBR works well but apparently the data signals do not work since I have mouse light but not working,
    Please help me to fix this problem, I read ideas
  • mon2
    • Dec 2019
    • 14027
    Re: help with samsung rv415 ba41-01649a
    According to the shared schematic, the USB connector has NO ESD protection devices; NO EMI filter and the data lines enter the USB controller (U516) directly.
    It should not come as a surprise that a simple ESD transient can nuke the USB host. Unbelievable that Samsung can put out such a design for the public. ESD protection devices are 3-5 cents (USD) in low volumes.
    There a bunch of USB based products on this logic board - see page 16/54 - U516 HUDSON - right side - such as USB camera; card reader, etc. - do they work in this computer?
    Check the Vbus voltage on each USB connector to confirm they are close to +5v.
    Check the voltage rails on each coil on the logic board - perhaps some other issue is causing this fault.
    Otherwise, could be a damaged USB controller (U516).
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      It could be bios issue as well. Yesterday i had a samsung LA-8861P with no usb port working and was fixed by bios flash. Mine was AMD though.
      • marcelofct
        • May 2019
        • 122
        • chile
        yesterday I did a bios flash but nothing happened, it's still the same
        • marcelofct
          • May 2019
          • 122
          • chile
          I'm going to review and let you know
          • marcelofct
            • May 2019
            • 122
            • chile
            I update the info, the webcam does not work, I do not have how to test the SD reader I assume that it does not work either, the voltages in the coils are ok, vbus voltages in the usb port vbus 5v stable I assume that the PCH is with problems
            attached image of task manager
            • Tom_avia
              • Jan 2020
              • 26
              • Lithuania
              Web cam is connected to the same USB port. If USB doesn't work, likely it is PCH.. replacement is required.
              Did you try BIOS dumb with clean ME?
              • marcelofct
                • May 2019
                • 122
                • chile
                Thanks for your answer, I have not tried with a clear ME, I will try but if it is the pch I don't have much to do
                  09-07-2024, 05:50 AM
                  09-06-2024, 11:40 PM
                  09-06-2024, 08:40 PM
                  09-06-2024, 06:20 PM
