Component blow up, Asus GL704
  • Sephir0th
    • Oct 2020
    • 1283
    Re: Component blow up, Asus GL704
    From where you sourced the BIOS? In General it isn't a good Idea to Programm via the Clip except you made Sure the dump isn't corrupt after programming.
    At least two or three oder bin's should be flashed and then Notice whether the behaviour Changes (even a little) or Not.
    FairRepair on YouTube
    • ZoOLf
      • Mar 2021
      • 61
      • NA
      #42
      hi,
      so i got the .bin from here in the forum it's 307 (the last version is 309).
      I used neoprogrammer as you suggested and the flash was successful ( as it was stated in the log)
      so you suggest that I find an older bios and flash it?
      • ZoOLf
        • Mar 2021
        • 61
        • NA
        #43
        please anyone any idea, Im stuck.
        • ZoOLf
          • Mar 2021
          • 61
          • NA
          #44
          so, after some testing with multimeter I think I shorted something and now I have the step-down controller TPS51258a getting very hot when charger is plugged.
          I will replace it when the chip arrive.
          • Steven.chbs
            • Oct 2021
            • France
            #45
            I have also a laptop GL704GM that stopped working, it dont turn on, I removed the battery and plugged the charger still not power. No led on with or without the battery/charger.
            I have 19V in entry but after I'm lost... If someone could help me on how to diagnose the problem?
            https://i.postimg.cc/NFJPtZ2W/IMG-20211009-000824.jpg
            https://i.postimg.cc/CMBPXMF4/IMG-20211009-003857.jpg
            • ZoOLf
              • Mar 2021
              • 61
              • NA
              #46
              hi again,
              so i changed that chip and i think as i was very bad on soldering it, something went bad when plugged the charger,
              now I have a short on the 5v rail, found a shorted mosfet, removing it didnt fixed the problem, still have 5v rail sorted,
              so I bought Powersupply and injected 1v and I have 0.3amps drain, but cant see anything hot,
              injected 3v the 5v rail drained 2amps I got a 1Ohm resistor going very hot
              so i removed it, still the 5v rail drain same 2amps,
              searching for what is going hot found this
              before injecting used rosin
              after injecting
              so its an RT8819a chip and a SOT-323 BAT54CW getting hot,
              found similaire config in another laptop
              as I dont trust my soldering skill, so I dont want to take any unnecessary risk on disordering those component.
              can be that SOT going bad or its the chip, or both? isnt 2amps alot for the SOT? as its rated 0.2ampers in its datasheet.
              what advise you can give me to continue the diagnostics.
              • ZoOLf
                • Mar 2021
                • 61
                • NA
                #47
                any idea?
                • mon2
                  • 14317
                  Hi. Need to check a few things before injecting any voltage onto the board. Can cause permanent damage if not followed carefully.
                  1) practice soldering on dead boards from AliExpress or eBay, etc.
                  2) source some good flux like Amtech but some clones can also work. We buy ours from AliExpress as the USA factory is useless.
                  3) a good hot air tool like Best station is what we have. It can be used for upto 550C and works well.
                  4) use meter in resistance mode and check for low resistance rails. If found, review for possible shorts. Voltage injection should be a last resort. The voltage for injection should always be low like 0v8 or 1v0 as long as the rail is actually higher than this value.
                  • ZoOLf
                    • Mar 2021
                    • 61
                    • NA
                    #49
                    Thx for reply
                    Im already doing what you suggesting, already fixed a 1070GTX MSI , was water damaged, did some mistakes burned some 0Ohm resistors and tracer but in the end managed to fix it.
                    but this laptop is making me crazy, no diagram no schematics, Im advancing with your help
                    • ZoOLf
                      • Mar 2021
                      • 61
                      • NA
                      #50
                      Update:
                      Removed the RT8819A IC, now im getting high resistance to ground and when i inject 1v there is no amps drain, ordered couple of IC, will update when they arrive, in meanwhile i will practice my QFN soldering.
                      • ZoOLf
                        • Mar 2021
                        • 61
                        • NA
                        #51
                        hi all,
                        so i Soldered the RT8819A IC now no short in 5v rail but im back to the first problem which is the TPS51258a getting very hot when 19v is present.
                        so when I inject 19v 1amps, in the 19v main rail that chip heat up, but when I inject less than 1amps (500mA) the chip is pulsing, i observe it with IR cam it, but I have a 6 pin chip with marking 8KB RX (RX is vertical) heat a little.
                        can you help me identify this chip?
                        pic attached.
                        • R_J
                          • Jun 2012
                          • 9555
                          Pjx138k Dual Mosfet
                          • ZoOLf
                            • Mar 2021
                            • 61
                            • NA
                            #53
                            thx, but after checking its not that chip, its th 822 resistor that goes hot,
                            after further inspection, desoldered the TPS51258a and injecting 19v found a Mosfet (PE616BA) pulsing which is connected to 3.3 rails, inspected it and its shorted to ground.
                            so i did inject 1v1A in that coil, the voltage drops to 0 with 1amps is drained but no heating present,
                            do i Increase the amps?
                            • ZoOLf
                              • Mar 2021
                              • 61
                              • NA
                              #54
                              update:
                              so, after injecting 1v2amps, i got the PCH heating up, so its shorted...
                              replacing PCH is it doable? with heat gun?
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                #55
                                Originally posted by zoolf
                                update:
                                So, after injecting 1v2amps, i got the pch heating up, so its shorted...
                                Replacing pch is it doable? With heat gun?
                                a big no no
