Sony SVP132A1CM V270_MBX REV 1.1
  • alfredodinolfo
    • 128
    • N/A
    mb: V270_MBX REV 1.1 1P-0134J00-8011
    laptop does not show pictures on its lcd panel, perfect on hdmi output.
    I change edp cable but not lucky. Boarview and schematic are not available.
    On FPC there are 10V and 3,3V maybe not present i2c line.
    some advice?
    thank you
  • peste
    • Dec 2016
    • 13592
    • ROMANIA
    Re: Sony SVP132A1CM V270_MBX REV 1.1
    some advice?
    thank you
    check display and video chipset ...
    • alfredodinolfo
      • 128
      • N/A
      on hdmi port work properly. display is not common
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Check LCD_VDD present or not?? Look for similar sony schematic.
        • alfredodinolfo
          • 128
          • N/A
          yes
          can you help me?
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            I'm already trying to help you. How many pins are there on screen connector on mb side??
            • alfredodinolfo
              • 128
              • N/A
              30 pin
              all pin 0v (no activity)
              1 - 3.3v
              18 - 7,5v
              19 - 7.5v
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                You wrote all pin 0V and on the other hand you wrote pin1 3.3V,pin18 -7.5V. Can u explain that first.
                • alfredodinolfo
                  • 128
                  • N/A
                  pin 1 3,3v
                  pin 18 7,5v
                  pin 19 7,5v
                  other 0v
                  • Carlos#2003%
                    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                    by Carlos#2003%
                    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                    02-15-2024, 07:52 PM
                  • dkneyle
                    Sony KDL-46HX850 Can't upgrade/update firmware
                    by dkneyle
                    Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                    Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                    09-25-2024, 10:44 PM
                  • rex98
                    JS47A/JS57A/JS77A NM-E531 onboard ram disable
                    by rex98
                    hi i have this laptop IdeaPad 3 15ABA7 this is the boardview https://www.badcaps.net/forum/troubl...90#post3740490
                    nm-e531 i tried all kinds of bios editing and it doesn't work. it doesn't have schematic but it has boardview with board ID details in it.
                    maybe you could help me how to shift these resistors to disable its onboard ram.
                    this is is the presents and not presents...
                    10-07-2025, 03:39 AM
                    Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                    This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                    09-06-2024, 05:27 AM
                    Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                    This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                    09-06-2024, 05:30 AM
