DH53F LA-F991P no power
  • ScorpioMan86
    • 94
    • South Africa
    Hi Guys,
    I have this Acer Predator laptop that was brought to me because it died while thermal paste was replaced with the battery still plugged in.
    The board model number is DH53F LA-F991P, I have done anything to the laptop yet other than disassembly.
    When connecting power to the laptop RT3607CE gets hot instantly, this is a Multi-Phase PWM Controller : https://www.richtek.com/Products/Vco...pecid=RT3607CE
    I have never faced this kind of issue before as i am still at the beginner level of repairs.
    Can i assume this chip is faulty because its hot ? ideally i would replace the chip and check if the replacement chip also gets hot, if not then i can probe further.
    I unfortunately dont have this exact chip on any of my donor boards, does anyone know what an equivalent replacement will be ?
    I dont think its safe to connect the charger if i remove RT3607CE from the board, unless i am wrong ?
  • acedogblast
    by acedogblast
    11-02-2024, 05:13 PM
    Common SPI bios chip programming Questions and Answers
    by SMDFlea
    Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
    A: If you can`t read from it how do you expect to write to it ?.
    Q: Why is my bios chip unreadable ?.
    A: The programmer is faulty or has a worn or broken zif socket.
    The USB cable is frayed,connector pins worn or some other physical damage.
    Not enough amperage or voltage to power the programmer properly.
    Bad...
    09-02-2021, 04:40 PM
  • BMCappelletti
    Asus Chromebox CN62 - wrong chip put on BIOS reader
    by BMCappelletti
    Long story short:
    - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
    - gave the computer to his son a couple years later
    - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
    - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
    (seems like the story was not that short)
    He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
    01-08-2025, 07:27 PM
  • Troystain
    Help EZP2023+ updated chip database for w25q256jveq?
    by Troystain
    Hello, anyone here have updated ezp2023+ chip database in .dat file format.
    I need to add w25q256jveq chip but I do not know what data should I type.
    I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
    The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
    11-25-2024, 12:53 AM
  • inck243
    Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
    by inck243
    Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
    The BIOS...
    07-25-2024, 09:17 AM
