asus e203n
  • jimmy2022
    • Feb 2021
    • 42
    • united kingdom
    asus e203n
    Hello people
    the diode and the coil seems to have shorted. the problem is that this part of the circuit seems to be connected to the 1.2 v rail which is part of the processor.
    i don't know if the short is in the processor , coil or diode.
    if i attempt to remove the diode/coil , what protection can i use for the processor so that it does not internally burn out.
  • Sephir0th
    • Oct 2020
    • 1283
    Re: asus e203n
    Exact Resistance to ground on that coil? Schematics available?
    FairRepair on YouTube
    • jimmy2022
      • Feb 2021
      • 42
      • united kingdom
      Re: asus e203n
      very difficult to get schematic. resistance in that entire circuit which i have highlighted is very low on a good working board 65.5 ohms.
      on this board somewhere around 20 ohms or less.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Re: asus e203n
        Remove the coil and measure resistance on both pads.
        • Sametbey
          • Jan 2021
          • 229
          • Turkey
          Re: asus e203n
          It does not damage the processor when you remove the coil and 220uF cap. Check two MOSFETs before coil. You can detect the heated part by giving 1v for the post coil.
          I'm not happy to be so strong. because it's not humanly
