Acer TMP259-MB-70RA processor heat
  • superdota2
    • Jun 2015
    • 64
    • PHILPPINES
    Acer TMP259-MB-70RA
    dazaamb16e0
    no power
    charging
    3v ok
    5v ok
    pl15 shorted to ground +1v_s5
    wheh i press power, consumes 0.456a
    processor hot, the rectangular chip not the square one,i think its the intel uhd, its it possible to cut +1v_s5 going to processor.
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    Re: Acer TMP259-MB-70RA processor heat
    In ohms value?
    PL15 will always be short to ground as low ohms
    456ma is ok with press
    • superdota2
      • Jun 2015
      • 64
      • PHILPPINES
      Originally posted by stingerchamp
      In ohms value?
      pl15 to ground 0.2 ohms, already flash bios i search here.
      • stingerchamp
        • Sep 2020
        • 425
        • Pakistan
        0.2 ohm is very low, I hope you checked in ohm or continuity range
        It proves indeed short, if you have schematic check supply is connected to which parts
        It seems core voltage or vccsa supply
        • superdota2
          • Jun 2015
          • 64
          • PHILPPINES
          when i press power,processor right side will get hot, and still no gpu,cpu,ram supply only 3.3v and 5v, bcuz +1v_s5 is short. hmmm
          • stingerchamp
            • Sep 2020
            • 425
            • Pakistan
            With schematic check power sequence
