lenovo Yoga 910-13IKB black screen
  • rascao
    • Jul 2020
    • 51
    • España
    Hello friends, i have a lenovo Yoga 910-13IKB when you turn on the led come on but the screen remain black no backlight nothing, the motherboard charge the batery, and i can find almost all the power lines in the on state, cpu, ran 3v 8v is the main one even with the charger plugin, 5 v, but the GFX power line remain 0, i check for short but on the multimeter give me the sound of a short but is like the CPU when is not energized the line is on short so no good info, i check the power schematics for the GFX and it have 2 "AOZ5029Q" for the job and they are not short and they are working because i exchange 1 from the gfx to the CPU and the cpu start to send Volts whit the replaced one, so the AOZ5029Q are working, i check the lines
    the 5v ios present and the 8v, i ges the gate is the PWM_GT2 FCCM_GT? and they have 2.3 v so there is working, but is not working so i dont know what else try
    It maybe is the on board ran that is bad? and if the ran is not good it will not energize the gfx power line? i upload the schematics and hope any one can help me whit this
  • emestee
    • Dec 2019
    • 228
    • Bulgaria
    Re: lenovo Yoga 910-13IKB black screen
    Please identify the board correctly and post schematics.
    I dont think there should be anything like 8V anywhere on the board.
    GPU power up is nearly the last stage of the power sequence and you should be speculating about the stage before that failing.
    To measure low resistance rails, use ohm mode and not diode mode.
    • rascao
      • Jul 2020
      • 51
      • España
      sorry didn't pres upload on the schematic, here it is, https://www.badcaps.net/forum/showthread.php?t=122737 and the board is CYG50 NM-A901 Agera-SVT rev 1.0, in the input of the charger there is 20v, after the first big coil it get 8v, the same 8 v from the battery is rated to 7.6v, if i remove the battery the rail remain as 8v, i did use the ohm is 10 OHMS from the gfx coils and 12 ohms from the cpu coil
      • emestee
        • Dec 2019
        • 228
        • Bulgaria
        What do you mean first big coil? The 20V rail has no coils on it. After the initial switching mechanism, it is distributed to secondary power supplies, none of whom should be accepting or producing 8V. So whatever coil you're measuring at isn't 20V and, more importantly, there is not and can not be anything like 8V anywhere on the board. You are looking at a fault. Please identify the coil.
        You need to test every rail, not just the cpu and graphics ones.
        • rascao
          • Jul 2020
          • 51
          • España
          PL12 is the coil i refer to big coil, is goin to the charging circuit and the main Vrail is what i see here, the battery is a 7,6 v rated one so for charging i think it is the 8v, that's why i think this motherboard uses the 8v as the main V rail because i see everywhere on the power circuits the 8v, that's why i think it was normal on this mother board as the VIN on PU25 PU29 and PU24 are 8v
          pd thanks for your time helping out
          • emestee
            • Dec 2019
            • 228
            • Bulgaria
            I see what you mean. Is this a netpad or some other miniature laptop? Having 8v for VIN would be a very.. unorthodox approach. I still dont think this would normally be the case, but I guess everything is possible.
            If 8V is the correct voltage, and the machine stops initializing before the graphic core is powered up, that's the part of the initialization sequence you will have to look at. I'd begin with standard RTC battery, oscillators, and coil resistance checks.
            • rascao
              • Jul 2020
              • 51
              • España
              the laptop is not as mini as you can imagine
              i will check that thing you are telling me thanks, i check the battery and is in good health, i take out the coils and they seems fine with the resistance as they should be.
              Is there any way the memory is not working and because of that the gfx is not initializing? because the ran is getting his volts, on the schematics i cant find the on sequence to be sure , and i don't find the BOARDVIEW for this model
              • emestee
                • Dec 2019
                • 228
                • Bulgaria
                It's possible, yes. You can test the RAM by measuring the 3.3, 1.5/1.35 and the reference voltage that's half of the 1.5/1.35 one. Don't forget to look at the power ok and enable signals.
                • rascao
                  • Jul 2020
                  • 51
                  • España
                  thanks for your help, i am a noob on this i will investigate how to thes the power ok and enable siglas thanks!
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    That 8V as main rail doesnt seems correct to me. What is the voltage on pin1/4/5 of DC-IN mosfets??
                    • piernov
                      • Jan 2016
                      • 4435
                      • France
                      Buck-boost NVDC topology, main power rail is taken from battery charging rail (after buck-boost converter), so it's normal to have a voltage close to battery voltage.
                      • emestee
                        • Dec 2019
                        • 228
                        • Bulgaria
                        This is why you're the grandmaster in these parts...
                        • rascao
                          • Jul 2020
                          • 51
                          • España
                          on the output of PQ15 and PQ16 i have 8.7 vots no battery connected just charger, and on the PQ10 and PQ11 i have 20v
                          • openminded
                            • Apr 2017
                            • 73
                            • home
                            I have the same issue and measurements. Any tips?
                            The isl 927 ?
                            • openminded
                              • Apr 2017
                              • 73
                              • home
                              I shorted PQ15 because I thought it was missing the gat signal, now I got 5.1 V instead of 20...
                              • Noursa
                                Lenovo Yoga C940-15IRH No primary Screen
                                by Noursa
                                Hello
                                I'am a beginner in electronics repair and i got some trouble to find what's goning on a computer. It is a lenovo yoga C940-15IRH laptop and the screen doesn't work anymore, but that work on an external one
                                the screen seams to be hard to unbuild properly so i want to test it by other way
                                how can i be sure if the signal is really send to the screen ? i did some check on screen connector on LCD1 got 19v and on MiC1 connector on the other side of the screen (dunno if it's for the screen itself or other thing) got a lot of 3.2v pin
                                did u got...
                                05-04-2024, 10:00 AM
                                Lenovo Yoga Yoga 6 13ALC7 Notebook Specification for Upgrade or Repair
                                This specification for the Lenovo Yoga Yoga 6 13ALC7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 6 13ALC7 boardview and Yoga 6 13ALC7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                09-07-2024, 05:00 AM
                                Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook 700 Specification for Upgrade or Repair
                                This specification for the Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 7i (16? Intel) 2 in 1 Laptop boardview and Yoga 7i (16? Intel) 2 in 1 Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                Lenovo Yoga Yoga 6 13ALC7 Notebook 700 Specification for Upgrade or Repair
