hp elitebook 745 G2
  • nassih
    • Oct 2015
    • 280
    • morocco
    hp elitebook 745 G2
    hi everyone
    i have an HP elitebook 745 G2.the problem is the power button and caps lock is blinking continuously when i put the adapter.
    i have replaced a bad mosfet and cleaning little water damage, but still the same problem no short to ground en all the coils .any ideas
    ps: all voltages is unstable still sensing except adapter IN rails
    best regard!
  • emestee
    • Dec 2019
    • 228
    • Bulgaria
    Re: hp elitebook 745 G2
    This is probably a problem with adapter detection. Measure the voltage on the central pin of the adapter.
    • nassih
      • Oct 2015
      • 280
      • morocco
      i have tested with original adapter its working on other hp laptop
      • emestee
        • Dec 2019
        • 228
        • Bulgaria
        Then start checking the circuit that's responsible for adapter identification.
        • nassih
          • Oct 2015
          • 280
          • morocco
          yes i have tested and replaced BQ25736, 3vs5 is present.all ALW voltage is present but its sensing not stable.
          • emestee
            • Dec 2019
            • 228
            • Bulgaria
            No, adapter identification goes through a separate circuit through an ADC or directly to a KBC input.
            What do you mean 'not stable'?
            • nassih
              • Oct 2015
              • 280
              • morocco
              i mean the voltage is random variable (19v~15v).,sorry my English is too bad
              ok,i have found a schematic for other hp model, https://www.badcaps.net/forum/showthread.php?t=85724 now when i put jumper between drain and source Q6010 the power button and caps lock is not blinking and the voltage is normal no random voltage but still no start
              • emestee
                • Dec 2019
                • 228
                • Bulgaria
                Ok, first off post the exact board model and revision.
                Second, without shorting the input mosfet (note that it's a p-channel), test its control circuit - Q6009, Q6013, ADP_EN. This is to make sure the mosfet is being controlled correctly. If when the main voltage is changing, and the control signal for Q6001 is changing too, you are getting closer to the problem.
                Third, do standard measurements on the charger - ACDET, ACPRES, REGN etc.
                Which bad mosfet have you replaced?
                • nassih
                  • Oct 2015
                  • 280
                  • morocco
                  OK, motherboard model:6050a2644501-MB-A02
                  Q6010 pin4= 6~15v pin1,2,3= 19.45v pin5,6,7,8=15v~19.45v.
                  ADP_EN= 1.8v~3.3v
                  replacd mosfet Q6010.
                  tanks
                  • nassih
                    • Oct 2015
                    • 280
                    • morocco
                    ACDET=2.6
                    ACPRES=3.2~3.3v
                    REGN =5.8~5.9v
                    all rest pins of U6000 is not stable except ACDET
                    • emestee
                      • Dec 2019
                      • 228
                      • Bulgaria
                      ACDET=2.6
                      ACPRES=3.2~3.3v
                      REGN =5.8~5.9v
                      Something is oscillating heavily. Do you observe current changes on the PSU?
                      • nassih
                        • Oct 2015
                        • 280
                        • morocco
                        1ma,Imaybe the kb chip no?
                        • emestee
                          • Dec 2019
                          • 228
                          • Bulgaria
                          I've only seen a case like this once and it was the PCH that was pulling voltages up and down, it was visible everywhere, even on BIOS power pins
                          You need to proceed carefully and write down the measurements. I would start cutting off various parts of the board and see if the problem goes away, beginning with input mosfets.
                            HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
                            This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                            09-07-2024, 05:50 AM
                            HP EliteBook EliteBook 650 15.6 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                            This specification for the HP EliteBook EliteBook 650 15.6 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 650 15.6 inch G9 Notebook PC boardview and EliteBook 650 15.6 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                            09-07-2024, 05:20 AM
                            HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                            This specification for the HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 630 13 inch G9 Notebook PC boardview and EliteBook 630 13 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
