Acer v5-471 no display
  • String2016
    • Nov 2015
    • 2238
    • philippines
    I need help on this acer v5-471 48.4TU05.04M laptop, at first laptop came here dead shorted PU4401 so replaced it and laptop turns on now, but the problem no display, already tried replacing ram with good one still same and external still no display,upon check voltages there in 3.3v and 5v and 1.5v on and vcore 1v, but there is no PLTRST# and DRAMRST#. Ive notice also PU4201 ISL95836 chip is very hot, upon checking pins pin 9 VR ON have 3.3v pin19 PGOOD 3.3V and PIN36 PGOODG 3.3V, anyone can help on this please
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Re: Acer v5-471 no display
    • stingerchamp
      • Sep 2020
      • 425
      • Pakistan
      Share schematic
      If your ic is ram ic check Suson,mainon signal at ic and ton voltage which is connected to PCH in some motherboard
      pltrst# is a signal coming from PCH,it is also indicate that your PCH is active if you get this signal then we can get slp-s5,S4 and S3# from PCH at coils and will generate state voltage.
      Check pltrst# signal going at which locations
      Or share schematic I guide
      • String2016
        • Nov 2015
        • 2238
        • philippines
        thank you for the response, here is the schematic
        • stingerchamp
          • Sep 2020
          • 425
          • Pakistan
          Ok now we have pltrst# signal after we get
          So_power_good which comes after we get slp_s3#
          First check these then check imvp_,, power good
          Use full signal name and where did you check it
          And share where did you check plt_rst# signal
          • String2016
            • Nov 2015
            • 2238
            • philippines
            i check the pltrst# on wifi slot pin22 there is no voltage there, also check dramrst# on pin30 on ram slot there is no voltage there, noticed PU4201 ic is getting hot
            • stingerchamp
              • Sep 2020
              • 425
              • Pakistan
              At page 36 you have small circuit for plt_rst#
              Q3601
              Check r3616 getting signal there
              At pin 37 of LAN RT you have plt_rst#
              Check voltage at r1908 resistor
              S0_PWR_GOOD as mentioned in previous post check it first then check imvp_pwgood because both are connected to and gate logic to generate sys_powerok to pch
              For dramrst signal you have at page 37 q3703 , check c3703 for short
              Check dramrst_cntrl_pch available at gate
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                if you dont have dramrst#, then why focus on pltrst#?? You are far from it. Pltrst# is one of the last signals. Concentrate on your RAM IC and do check Q3703 as suggested. You can even remove Q3703 and power up the mb and see if dramrst# rises.
                • String2016
                  • Nov 2015
                  • 2238
                  • philippines
                  Thanks for the response, i cannot find he Q3703 located on board
                  • String2016
                    • Nov 2015
                    • 2238
                    • philippines
                    I found q3703 s=3.3v both drain and gate 1.5v c3703= other side have 3.3v but other side have 0v
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Q3703 measurements proves its working and dramrst# is present. Are you sure you measured on pin30 of dimm slot and there is no voltage?? It seems very unlikely. Re-measure it if possible.
                      • String2016
                        • Nov 2015
                        • 2238
                        • philippines
                        still no dramrst# on pin 30 of the ramslot
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Check continuity between Q3703 drain pin to pin30 of ram slot. Are you counting the pin correctly??
                          • String2016
                            • Nov 2015
                            • 2238
                            • philippines
                            I double check it from dran of q3703 to pin 30 0f ramslot there is no beeping
                            • emestee
                              • Dec 2019
                              • 228
                              • Bulgaria
                              Take a looking glass and a good light source and look at the back of the DRAM slot. May be a cold joint or mechanical damage hiding over there.
                              • String2016
                                • Nov 2015
                                • 2238
                                • philippines
                                already tried that, also tried resolder each pin still no DRAMRst# on pin 30
                                • stingerchamp
                                  • Sep 2020
                                  • 425
                                  • Pakistan
                                  If at drain you are getting 1.5Vol then q3703 is working
                                  and it is connected to pin 30 of reset signal at ram slot
                                  What is voltage exact value at
                                  Pins ,1 ,199,126 ,200,202, 203,204 , 75 ,30
                                  Remember we need 1.5voltage at pin 30 not 3.3v
