Acer E5-575 (mobo DAZAAMB16C0) shuts down
  • PinGuy
    • Oct 2016
    • 74
    • Argentina
    Owner said it couldn't load Windows, because it would shut down on its own, then after power up again, it tries to "Automatic repair", then shut down before finishing the repair, then again...
    Ok, at my first check, the laptop started perfectly. It was left playing Youtube, then after more than 3 hours, it suddenly shut down. After that, the original problem started again, i.e. it gets to the Acer logo then off.
    Sometimes it lasts about 1 min, then off again.
    Nothing is hot, and it doesn't seem to be a temperature problem as it happens even when cold.
    I see this issue is common for this model, but while working on battery, as it has a switch on the bottom RAM cover that tends to fail and shuts it down. But on this one it happens while plugged in too, and the switch is measured well.
    Could it be the thermal protection circuit is tripping falsely?
    It confuses me that it worked for more than 3 hours at first without any issues
    TIA for any clues on this.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Acer E5-575 (mobo DAZAAMB16C0) shuts down
    Flash known good bios with clean me.
    • PinGuy
      • Oct 2016
      • 74
      • Argentina
      Thank you, @mcplslg123!
      I flashed the one you provided at post #5 here:
      https://www.badcaps.net/forum/showthread.php?t=80118
      And so far, it's been 15 minutes and it is still on!
      I don't know why it takes 15 seconds to post the Acer logo when turned on, though. Is this due to ME disabled or something like that?
      I tried saving settings on the bios setup, but nothing changed.
      Just in case, I am attaching my original bios.
        • 21889
        Post your bios in the "Bios Requests ONLY!" section if you want it repairing/ME cleaning . https://www.badcaps.net/forum/forumdisplay.php?f=40
        It boots in 15 seconds becuase the bios you tried is "initialised" which means the ME firmware isn`t clean.
        • PinGuy
          • Oct 2016
          • 74
          • Argentina
          Oops, I spoke too soon. I went to see it and it was off. Now it turns on a few seconds, then goes off again. It doesn't reach even the logo
          • PinGuy
            • Oct 2016
            • 74
            • Argentina
            All right, problem solved. The issue is on the f'ing keyboard!!!
            It turned strange that sometimes power turned on as soon as the charger was plugged. After disconnecting the keyboard, the laptop won't go on after connecting the charger, and it won't go off anymore.
