Toshiba satellite m645 fluctuating voltage
  • String2016
    • Nov 2015
    • 2238
    • philippines
    I need help on this please , I have a problem with this toshiba satellite m645 NBQAA LA-6071P REV 1.0.The problem is fluctuating voltage of PQ8 voltages start from 16v then fluctuate to drop and same on current sense resistor PR45. attached is the schematic , can someone please help the problem of the laptop when pressing power button 1 second goes off
    • 21936
    Re: Toshiba satellite m645 fluctuating voltage
    Any voltage measurements ? , have you checked all the mosfets ? .You should know by now that the more info you can give the more likely you are to receive help.
    • String2016
      • Nov 2015
      • 2238
      • philippines
      Already check PQ7 Both sides have 19v but Pq8 S=19V but drain is fluctuating voltage only 16v then drop
      • String2016
        • Nov 2015
        • 2238
        • philippines
        anyone could help on this please
        • Techtiger
          • Oct 2014
          • 1602
          • france
          1st do a cool check up PQ7/8/6 S D G Diode mode is those Fets are ok what is voltage on be Gate of PQ7/8? Is the pin 4 of 2 fets +8V ?
          • Techtiger
            • Oct 2014
            • 1602
            • france
            Remove PJ18 & check if the fluctuatingbis gone
            • String2016
              • Nov 2015
              • 2238
              • philippines
              pq7 s=4.6k g=4.9k d=59.8 on pq8 s=4.6k g=4.9k d=21.8k on voltage pq7 s=19v g=19v d=19v pq8 s=19v g=19v d=16v fluctuating dropping voltage, i cannot find pj18 on the board i only found pj17
              • Techtiger
                • Oct 2014
                • 1602
                • france
                May be PQ8 faulty test it on Diode mode , & the 1st 2fets are not switching find out PACIN Voltage?
                PQ7/8 For P-Channel Fet
                Red Pro to Drain Black Pro to Sorce no Value or High
                Red Pro to Source Black Pro to Drain Value 50-500 ohms
                Red Pro to Source Black Pro to Gate No Value or high
                Red Pro to Drain Black Pro to Gate No Value or high
                • String2016
                  • Nov 2015
                  • 2238
                  • philippines
                  thanks for the response, pq7 is good but pq8 Red Pro to Source Black Pro to Drain Value 50-500 ohms = no value, I already tried removing pq8 and check on drain side without it still fluctuating voltage
                  • String2016
                    • Nov 2015
                    • 2238
                    • philippines
                    removed pq7 and test still voltage is fluctuating on pq8
                    • String2016
                      • Nov 2015
                      • 2238
                      • philippines
                      tried removed both pq7 and pq8 still same fluctuating vltage
                      • String2016
                        • Nov 2015
                        • 2238
                        • philippines
                        anyone please help
                          • 21936
                          check resistance on PQ6 s/g/d
                          • String2016
                            • Nov 2015
                            • 2238
                            • philippines
                            here it is
                            PQ6
                            Red Pro to Drain Black Pro to Sorce = 0.400
                            Red Pro to Source Black Pro to Drain = goes for 1.6 then fluctuate to no value
                            Red Pro to Source Black Pro to Gate=no value
                            Red Pro to Drain Black Pro to Gate= no value
                            • Techtiger
                              • Oct 2014
                              • 1602
                              • france
                              After removing PQ8 what is the voltage on the drain side ? Do y have the DC LAB?
                              • String2016
                                • Nov 2015
                                • 2238
                                • philippines
                                @techtiger removing pq8 voltage on the drain side same 16v fluctuating, i have bench lab and already tried injecting voltage nothings happens it taking only 0.125amps
                                • String2016
                                  • Nov 2015
                                  • 2238
                                  • philippines
                                  even pq6 both drain and source are fluctuating voltage
                                  • Techtiger
                                    • Oct 2014
                                    • 1602
                                    • france
                                    Remove PR45 and feed back which site is fluctuationg ?
                                    • String2016
                                      • Nov 2015
                                      • 2238
                                      • philippines
                                      removed pr45 both sides fluctuate
                                      • String2016
                                        • Nov 2015
                                        • 2238
                                        • philippines
                                        anyone can help
                                          Toshiba Satellite Pro R50-C-185 Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro R50-C-185 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the R50-C-185 boardview and R50-C-185 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 06:10 AM
                                          Toshiba Satellite Pro A50-C-2JL Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A50-C-2JL Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A50-C-2JL boardview and A50-C-2JL schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 06:08 AM
                                        • triplefour
                                          ONN 100012588 Has fluctuating Voltage on PSU 12v
                                          by triplefour
                                          Hello all got another TV here im puzzled by. why cant they all be easy fixes that just need a little love and some tape???
                                          anyway i go to this guys house to look at an ONN 100012588
                                          this is my first time looking at one of these brand of TV's.
                                          TBH i have low expectations because i see ONN as the cheap walmart brand that suddenly popped up selling the cheapest version of all kinds of tech things. and someone sent me a ONN flash drive with some data on it with some recordings they wanted me to check out and it immediately broke and corrupted the data and i was unable to...
                                          09-14-2022, 07:41 PM
                                          Toshiba Satellite Pro A50-D-110 Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A50-D-110 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A50-D-110 boardview and A50-D-110 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 05:35 AM
                                          Toshiba Satellite Pro A50-EC-1QC Netbook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A50-EC-1QC Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A50-EC-1QC boardview and A50-EC-1QC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 10:00 PM
