Acer Aspire E1-532-2635 turns on, black screen, fans run 1/2 sec and won't boot
    • 21922
    Re: Acer Aspire E1-532-2635 turns on, black screen, fans run 1/2 sec and won't boot
    If it boots then resetting the CMOS has worked.If not,then i`d get hold of some known working memory from another laptop.Its DDR3L.The next step after that is to take the motherboard out and start checking the voltage on all the large square grey coils.
    • DXseekerMO
      • Feb 2018
      • 1119
      • US
      Originally posted by smdflea
      if it boots then resetting the cmos has worked.if not,then i`d get hold of some known working memory from another laptop.its ddr3l.the next step after that is to take the motherboard out and start checking the voltage on all the large square grey coils.
      it booted!!!!!!
      They call me......."threadkiller"
      • DXseekerMO
        • Feb 2018
        • 1119
        • US
        Ok so everything looks like it's still there, save for the two screen icon where I connect to the internet and the clock is wrong, month, date and year but as soon as it fully booted I snagged my inventory from the clutches of death and saved them to my USB stick!! All the items were there! If it's just a missing icon and an inaccurate clock I feel like I dodged a bullet!!
        Apparently I was getting an update when I shut it down....and the update is now downloading where it left off.
        Under no circumstances could/would I have done this if it wasn't for your help SMDFlea. Thank you, I appreciate your help and expertise!
        Should I be watching for anything kooky with the machine after this point? Also can I fill that empty RAM slot with another card like you mentioned above?
        • DXseekerMO
          • Feb 2018
          • 1119
          • US
          Well that didn't last longer than a snowball on a hot griddle. It updated and shut down then wouldn't reboot.
          • DXseekerMO
            • Feb 2018
            • 1119
            • US
            Well I'm not sure now what's up.....after several tries it booted. Strange. I'm checking for updates again just for the heck of it.
            I can't help but wonder if this RAM card has an intermittent problem, or maybe a bad solder joint or single component failing upon the motherboard, like a transistor that's getting ready to take a dump?
            I may try to re-seat the RAM card one more time and see what happens.
              • 21922
              Originally posted by DXseekerMO
              it booted!!!!!!
              .Now you can set the time and date in the bios. Press F2 or Del to enter bios setup . Some updates will bork unless the time/date is set up .
                • 21922
                Check the ram using memtest86 ,you can make a bootable USB key. Check the hard drive too.From an admin command prompt type chkdsk /r /f C: .Choose yes to run at next boot.
                • DXseekerMO
                  • Feb 2018
                  • 1119
                  • US
                  #28
                  Is this as its booting up? I did set the time at the clock on the lower right side of the screen, is that the same?
                  Is this memtest run from the admin command prompt as well?
                  It took about 20 attempts this time but it finally booted again so I can run these tests now. Also if I select "restart" instead of shut down it will reboot OK. The problem seems to be when the machine is booted from a fully off state.
                  • DXseekerMO
                    • Feb 2018
                    • 1119
                    • US
                    #29
                    I did check in bios, the time and date are correct. EDIT/ADD: I ran chkdsk. Seemed to run kinda fast, near instant results. It said the volume was clean.
                      ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                      This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                      09-12-2024, 03:28 PM
                      ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                      This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                      09-12-2024, 02:30 PM
                      ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                      This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                      09-06-2024, 05:27 AM
                      ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                      This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
