HP zbook 15u g3, doesn't work with AC
  • mastsrl
    • Apr 2019
    • 38
    • Argentina
    i have a curious issue with a HP zbook 15u g3 (motherboard 6050A2822301-MB-A01):
    It doesn't work with the AC adapter plugged AT ALL, it doesn't charge the battery either.
    When you plug the charger, the notebook "turns on"(power led, no video) for ~2s and turns off.
    If i charge the battery externally, the notebook works perfect, but it doesn't detects the AC adapter at all(nor charges it, it also don't get no adapter warning).
    It's not a blown pass mosfet either, because without battery, it turns on for 2s and i also have 19V on the internal power rail, since i can't find any schematic for this motherboard maybe someone had any ideas.
    I'm thinking that the AC adapter identification circuitry must be fried(as some HP notebooks won't turn on without a specific identified AC charger, nor charge the battery), but without schematics i'm not sure how it reads it in this model
  • Techtiger
    • Oct 2014
    • 1601
    • france
    Re: HP zbook 15u g3, doesn't work with AC
    Find out what is Charging IC ID BQXXX ect & find out pin ACOK ACIN from schematic or PDF then The voltage of those pins what is the the Voltage on the 1st 2Fets
    • mastsrl
      • Apr 2019
      • 38
      • Argentina
      I did check with the datasheet and everything seems ok:
      ACDET is at 2.77V, ACOK is at 3.33V
      ACDRV is at 25V and both input mosfets are active and passing the 19V to the internal bus
      yet it doesn't turn on
      • Techtiger
        • Oct 2014
        • 1601
        • france
        What is your Charging IC & SIO ?
        • mastsrl
          • Apr 2019
          • 38
          • Argentina
          The controller is a TI bq24780s, SIO is nuvoton npce586ha0mx
          More testing i did and reverse engineering to find the components and some oddities, did a table with AC, BAT and BAT+AC:
          AC Only:
          As i stated in the previous post: internal rail is at 19V:
          ACDRV: 26V
          BATDRV: 12V
          VCC: 19,26V
          ACOK: 3.33V
          BATT(battery terminals): 11,9
          PHASE: 20,78 (this is an oddity, the phase pin has 20.78 DC, but the battery connector has only 11,9V)
          i also checked extra pins:
          REGN: 5.96v
          BATPRES_: 0v
          Battery only:
          ACDRV: 0
          BATDRV: 17
          VCC: 10,63
          ACOK: 0
          BATT(battery terminals): 11,59 (battery is fully charged)
          REGN: 0v
          BATPRES_: 0v
          Batt+AC:
          ACDRV: 25,7
          BATDRV: 12.75
          VCC: 19
          ACOK: 3,33
          BATT(battery terminals): 12,58
          PHASE: 16,42
          REGN: 5,9v
          BATPRES_: 0v
          both charging FETs are getting warm, but the notebook doesn't show charge nor battery detected, i haven't checked PWM waveform yet, but it does seems like hte BQ is indeed charging the battery
          • mastsrl
            • Apr 2019
            • 38
            • Argentina
            any idea?, i haven't been able to solve this problem yet
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Check your battery discharge fet . Its likely shorted.
              • mastsrl
                • Apr 2019
                • 38
                • Argentina
                if the battery discharge fet is shorted, then it wouldn't work with battery(or battery would overheat and last very little or blow the fet), yet it is working normally on battery and i've not noticed any fet heating up on batt.
                i will recheck for shorts but i don't think i found any
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Why it wont work from battery if discharge fet is shorted?? IF the fet is shorted, battery current will directly flow from drain to source of the mosfet and power the whole mb.
                  • mastsrl
                    • Apr 2019
                    • 38
                    • Argentina
                    ah sorry i answered without the actual datasheet in front of me and the discharge fet you mention is the "battery drive" FET driven by BATDRV, since you said discharge i thought it was the low side drive FET(LODRV).
                    i will check that FET today
