Acer Aspire one D270 Turning Off in Second After Pressing Power Switch
  • mygemsga2019
    • Aug 2020
    • 21
    • Philippines
    Please help to troubleshoot Aspire One D270.
    After Pressing power On the LED indicator goes On and Goes OFF right away. Bios Voltage is present 3.3V so as the Power switch. No Short in Main Power rail.
    Here's my issue the Voltage in PU3 is not Normal it says different from the schematic. I don't know the reason and how to solve the issue. Please see the Voltage in PU3 below.
    1. 0.8 v
    2. 0v
    3. 2v
    4. 0v
    5. 0v
    6. 0.4v
    7. 3.4v
    8. 3.4v
    9. 8.2v
    10. 3.4v
    11. 3.4v
    12. 0v
    13. 3.1v
    14. 0v
    15. 0v
    16. 19v
    17. 5.2v
    18. 3.4v
    19. 0v
    20. 5v
    21. 0v
    22. 8.7v
    23. 1.2v
    24. 5.2v.
    Do I need to replace the chip or if there is another way around to solve the issue. Thank you to all
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Acer Aspire one D270 Turning Off in Second After Pressing Power Switch
    Entrip2 at 0.4V is too low(pin6). Without having voltage at FB1/FB2 you wont have output on 3v/5V coil. Vreg3/vreg5 are ok. There are other anomalies like gate voltages but those can be looked later. Check all the resistors connected to Entrip and FB pins. If all seems okk, replace the IC.
    • mygemsga2019
      • Aug 2020
      • 21
      • Philippines
      Hi mcplslg123, Thank you for the reply. There's only 1 resistor connected to PU3 Pin6(PR69) which I think faulty(70k ohm), it is so suppose to 4.7k Ohms. So I replace it with 5k ohms if that would be Okay? But same thing happen still not powering on. So I decided to reheat the PU3 and boom its working. I'm so glad that I fixed this one. Running for 2 hours now I wish that theres no other issue. Thank you for the help highly appreciated! I will update the status later once everything's fine. Stay safe!
      • mygemsga2019
        • Aug 2020
        • 21
        • Philippines
        Update: Running for few hours now so far no issue...
        PS: I forgot to mention in my previous comment that I also replaced PC58 caps with Tantalum caps
        • mygemsga2019
          • Aug 2020
          • 21
          • Philippines
          Update: After 7hours of Testing the unit suddenly shut off. When I switch On again the issue is back. Battery charging indicator is still ON. Any input please to solved this issue. Thank and stay safe!
          • lapfix
            • Mar 2020
            • 2750
            • my workshop
            Replace PU3
            • mygemsga2019
              • Aug 2020
              • 21
              • Philippines
              Originally posted by lapfix
              Replace PU3
              @lapfix Thank you. I replaced PU3 once the IC arrived already ordered. I will update this thread after I replace the PU3. Thank you and Stay safe!
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                I had this doubt when you said on heating PU3 it worked. There is likely to be broken internal connection inside the ic which is temporarily restored due to heating. Always replace the IC in such scenario-else it'll keep coming back to you at regular intervals.
                • mygemsga2019
                  • Aug 2020
                  • 21
                  • Philippines
                  @mcplslg123
                  I replaced the PU3 and tested the unit. And after 11 hours the unit restarting itself I thought It was just okay since it is working again but after several hours the unit turned off. Try pressing the power it will Turn on for several minutes then turn off again.
                  Is the PU3 Faulty again?
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Could be PU3 faulty but could be some thermal trigger issue and can even be a dying atom cpu.
                    • mygemsga2019
                      • Aug 2020
                      • 21
                      • Philippines
                      I will replace again the PU3 hope it works.
                        ACER Aspire Aspire X3910 Aspire E5700 Specification for Upgrade or Repair
                        This specification for the ACER Aspire Aspire X3910 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X3910 boardview and Aspire Aspire X3910 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                        09-12-2024, 03:36 PM
                        ACER Aspire Aspire XC-886 Aspire XC i5-9400 Specification for Upgrade or Repair
                        This specification for the ACER Aspire Aspire XC-886 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-886 boardview and Aspire Aspire XC-886 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-12-2024, 03:30 PM
                        ACER Aspire Aspire XC-330 Aspire XC A4-9120e Specification for Upgrade or Repair
                        This specification for the ACER Aspire Aspire XC-330 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-330 boardview and Aspire Aspire XC-330 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        ACER Aspire Aspire R3600 Aspire 230 Specification for Upgrade or Repair
                        This specification for the ACER Aspire Aspire R3600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire R3600 boardview and Aspire Aspire R3600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                        09-12-2024, 03:28 PM
                        ACER Aspire Aspire Revo R3600 Aspire 230 Specification for Upgrade or Repair
                        This specification for the ACER Aspire Aspire Revo R3600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire Revo R3600 boardview and Aspire Aspire Revo R3600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
