No display asus x540up rev 2.0
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Hi good day to all I have this asus laptop board was spilled with milk the the bord wont display from the lcd tried removing the lvds connector and tried HDMI output ,it will show display checking all voltage on the board edp board has 19v power (L5406 RESISTOR 80OHM) testing the SCHOTTKY pin 2 has 3v output (LCD BACKOFF)
    If someone encountered this type problem please give me some advice higly appriceted
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: No display asus x540up rev 2.0
    Does the mb posts?? Check usb kbd NUMLOCK key glowing or not.
    • Luaina
      • Sep 2016
      • 12
      • Madagascar
      Check all the voltage surrounding the LVDS connector
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        it has display but it only flicker i already tried change the lcd
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Change backlit coil on screen-many asus has this problem.
          • kalilinux25
            • Mar 2018
            • 2089
            • ZAMBOANGA SIBUGAY
            i allready tried changing new lcd same it wont display sometimes it will display very low light and flicker at the same time
            • sgcampion
              Asus rog strix scar 17 G733QR display Issue(flicker, black/white))
              by sgcampion
              My Asus laptop started flickering from time to time and more and more in last months. First the screen was going black but sometimes if I moved the screen it would work again, other times I needed to plug/unplug the laptop or close and open the lid to make it work again.
              In last days I see that if I move the laptop lid to about 45 degrees it will flicker or get white or black screen(it's random, sometimes white sometimes flickers etc). I was trying to troubleshoot it myself but seems like it's either the cable or the display....
              10-24-2023, 09:39 AM
            • JhonnyF92
              Asus Rog Strix G513 Display no image
              by JhonnyF92
              Hi! I have a problem with my laptop Asus Rog G513 RC .The laptop have no image on display only on HDMI tv/extern monitor.I replace the display with a new display ,reset the graphics cards drivers,disconnected the Ram,Display cable battery ,motherboard,update the bios to a older version and nothing works so far.I didn t find the battery to reset the bios.
              The laptop have 2 graphics cards. A internal one from CPU Ryzen 7 6800u and dedicated Nvidia RTX 3050.
              10-14-2023, 03:27 AM
            • razor_amd
              by razor_amd
              12-15-2020, 07:07 PM
            • kalilinux25
              ASUS H81M-K auto power on no display
              by kalilinux25
              **Hardware: ASUS H81M-K**
              **Issue: No Display Upon Power On**
              **Steps Taken for Troubleshooting: BIOS Flash to Latest and Lowest Version, Resistance to Ground Checked for Short Circuits**
              **Explanation:** The ASUS H81M-K motherboard exhibits a peculiar issue where the system powers on, but no display is observed on the monitor. The symptoms include the motherboard receiving power and the power supply unit's fan spinning, along with the CPU fan if the power outlet is connected.
              In an attempt to resolve this problem, the following steps were undertaken:...
              09-20-2023, 08:45 PM
            • Xenvleid
              1080p to 4K Laptop Display Upgrade on Asus TUF F17, is it possible?
              by Xenvleid
              So recently I purchased a 2022 Asus TUF F17 laptop off Amazon considering it seemed to be a great piece of equipment for the price point. The model is FX707ZE but there was an oversight on my behalf, the display, which is total garbage. That being said I did some research and apparently people are able to upgrade certain display based on very specific compatibility requirements. Causing me to spend the last 5 hours hyperfocusing on what seems like it's never been done to this specific model.
              I want to upgrade it because of how terrible it is. I was able to find an upgrade 4k replacement...
              05-13-2023, 11:35 AM
