GL753VD shutdown during 3d test
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Asus GL753VD bought on ebay from a friend of mine as from parts or repairs.
    The unit starts and on Windows 10 the discrete gpu (gtx1050) it's recognized apparently no other problems. I am not in my lab, so I do not have the proper equipment only an old Toshiba adapter 19V 6.32 A and 4G ddr4 . With the performance test app , 5-6 seconds after starting the 3d test (the video stars and I cans see fps) , the unit turns off.
    Is it possible that not enough power or ram?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: GL753VD shutdown during 3d test
    Very likely not enough power.
    • chegueva
      0.01% progress
      • May 2017
      • 21
      • ALG
      Try to get your hands on the right wattage adapter first then we go from there.
      • jasko_jacker
        • Oct 2014
        • 1137
        • italy
        Probably, but I see that the original adapter is 6A.
        If the GPU chip has problems, what is the signal that forces shutdown? FORCE_OFF_PWR or GPU_ALERT or ???
        • jasko_jacker
          • Oct 2014
          • 1137
          • italy
          When the battery is connected, the notebook does not start, the battery led flashes white or red without a particular sequence.
            • 20666
            Did you monitor the temps and is the battery in good condition.
            https://cdn.badcaps-static.com/pdfs/...b3bfe4c79d.pdf
            EDIT: can you check the battery with batterymon - https://www.passmark.com/products/batmon/
            2nd edit: sorry didn`t see your post.
            • jasko_jacker
              • Oct 2014
              • 1137
              • italy
              I have added some info about BQ24735, I don't know how it don't start evean the battery is gone, but the battery give a voltage around 12 V not 0V
              • jasko_jacker
                • Oct 2014
                • 1137
                • italy
                Maybe the problem is on the bq24735, with battery and power supply the AC_BAT_SYS is 12V sometime 19V.
                • piernov
                  • Jan 2016
                  • 4435
                  • France
                  If there is a high load on the system and the AC adapter cannot provide the required power, the charger IC can switch to battery power instead. As a result some laptops won't work properly under high load without a perfectly good battery.
                  • jasko_jacker
                    • Oct 2014
                    • 1137
                    • italy
                    The problem now is that with AC+batt sometime AC_BAT_SYS is not 19V but is equal to battery voltage. When I insert AC BATDRV for 1-2 min is equal to SRN (equal to battery voltage) and the BATDRV FET is off but after that BATDRV (pin 16 of bq2435) rise to SRN+6v and in this case BATDRV FET is on and AC_BAT_SYS is now equal to battery voltage. I try with another battery and this behaviour is the same. I replace the BQ24735 , check REGN.
                    It is also possible that both batteries are not good but does this justify this behavior?
                    • jasko_jacker
                      • Oct 2014
                      • 1137
                      • italy
                      With original adapter and 8G DDR4:
                      1- I set on NVIDIA as default dedicated GPU
                      2- i force chrome to use dedicated gpu
                      3- on youtube no shutdown, the gpu core around 600MHz
                      4- with heavy test , shutdown occurs
                      a- I disable NVIDIA driver
                      b- with integrated gpu no shutdown occurs
                      After shutdown if I don't remove the adapter the system don't start.
                      any idea ?
                      • jasko_jacker
                        • Oct 2014
                        • 1137
                        • italy
                        After shutdown AC_BAT_SYS is 1V -> remove adapter -> reinsert and go to 19V
                        • piernov
                          • Jan 2016
                          • 4435
                          • France
                          Is that with battery connected and charged?
                          • jasko_jacker
                            • Oct 2014
                            • 1137
                            • italy
                            Now I can confirm that with a new battery, full charged, the system don't start and it has the same behaviour with the old battery and the battery does not charge (battery led blinck white/red)
                            I see that the smbus is connected with the ITE (I check it's firmware and don't find any issue), it's possible that the problem is on ITE ?
                            • jasko_jacker
                              • Oct 2014
                              • 1137
                              • italy
                              Solved but I don't know why.
                              The solution is reprogramm bios, of course, someone would say. Usually I don't do things that I don't consider related to the failure, in this case, the ITE firmware is not in the main bios, could someone explain to me the correlation between the bq735 and the main bios?
                                • 20666
                                Flashing the bios fixes everything
                                • bachir2004
                                  • Feb 2015
                                  • 437
                                  • maroc
                                  Weird anomalies with unlikely solutions.The beauty of fixing electronic devices.
                                    ASUS ROG GL753VD-GC119T Notebook Strix Specification for Upgrade or Repair
                                    This specification for the ASUS ROG GL753VD-GC119T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL753VD-GC119T boardview and GL753VD-GC119T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                    09-06-2024, 06:11 AM
                                    ASUS ROG GL753VD-GC324T Notebook Strix Specification for Upgrade or Repair
                                    This specification for the ASUS ROG GL753VD-GC324T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL753VD-GC324T boardview and GL753VD-GC324T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                    ASUS ROG GL753VD-GC003 Notebook Strix Specification for Upgrade or Repair
                                    This specification for the ASUS ROG GL753VD-GC003 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL753VD-GC003 boardview and GL753VD-GC003 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                    ASUS ROG GL753VD-GC011 Notebook Strix Specification for Upgrade or Repair
                                    This specification for the ASUS ROG GL753VD-GC011 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL753VD-GC011 boardview and GL753VD-GC011 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                    ASUS ROG GL753VD-GC148T Notebook Strix Specification for Upgrade or Repair
                                    This specification for the ASUS ROG GL753VD-GC148T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL753VD-GC148T boardview and GL753VD-GC148T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
